The "What did you work on today" thread.
Old Jun 25, 2017 | 09:21 PM
  #261
Wide_Tyres_2's Avatar
Default Black Grille for my Black Cat
before and after... looks more stealthy... added an R on grille too
Old Jun 25, 2017 | 11:49 PM
  #262
Johnken's Avatar
Usually I don't like the blacked out look, but yours is sharp.
Old Jun 26, 2017 | 12:46 AM
  #263
prettybluefin's Avatar
Replaced the Rear Fog Light bulb. Replaced the left side 2 weeks ago...
Grateful it's easy to access them from the boot!
Old Jun 26, 2017 | 12:47 AM
  #264
[QUOTE=Wide_Tyres_2;1709752]before and after... looks more stealthy... added an R on grille too
SOO nice! THere are some things that only look good on a solid black car, and that grill is one of them. Billy is gonna want one...
Old Jun 26, 2017 | 10:33 PM
  #265
rothwell's Avatar
I had to R & R the driver side rear window regulator yesterday.
I detailed the DIY in my working thread
Old Jun 28, 2017 | 12:10 AM
  #266
robaroni's Avatar
Went down to Marco Mufflers and had the center muffler removed. Added straight pipes and and cross pipe. Can only notice the difference under moderate to heavy acceleration. Didn't get as much growl as I was wanted but it does sound good. Can always cut more down the road.
Also tightened up the throttle cable. It had more than a 1/2 inch slack!
Old Jun 30, 2017 | 11:15 PM
  #267
Wagon Willie's Avatar
Default Modified the dead pedal (footrest)
I found the XKR a bit uncomfortable as I couldn't find a good spot for my left foot and leg. The footrest is way, way back there! I could touch it with my foot, but it certainly wasn't in an ideal spot. After looking at how others modified theirs I did a similar thing but followed the "design as you go" school. I removed the old assembly altogether and cut and fit a wooden block to lift the pedal approximately 5" (125 mm) from the carpet, replacing the old plastic riser. It's still a bit lower than the brake pedal and a bit closer to it than stock, but I like it. It's close enough to where it's very difficult to get your foot between the footrest and the brake pedal, which is a good thing, I think, from a safety standpoint.
Easily done: remove the old rest, unbolt the base, disassemble the actual footrest from the underlying plastic and reassemble using a shaped wooden block. The wooden block has holes drilled all the way through it to give access to the bolts that hold the original base down and is screwed to the base from the back with pan head wood screws. Other wood screws then hold on the plate that your foot actually rests on to the wood block, covering the big holes that are bored through the wooden block. Block is painted semigloss black so it "disappears".
Base plate
Floor with everything removed
Wood block added, still needs wedge under part of plate
Finished installation
Old Jul 1, 2017 | 06:28 AM
  #268
dsd's Avatar
dsd
I replaced my crankcase breather hose that was repaired many times.
I was able to source 90 degree Norma V2 connectors and another member has uprated flex hose that he attached. My XKR was actually one side 90 degree the other side straight but with a bit of extra slack in the hose it connects fine with the two 90s.
Old Jul 3, 2017 | 04:01 AM
  #269
Salo's Avatar
Smile Clear / White side indicators and bumper lights
Hi All,
share some pics of my new white/clear side indicators and bumper lights - great improvement compared to the old orange ones.
note: the side indicators was easy to swap, but the bumper ones I had to crack the old orange class and clue the new white ones in place
silver XKR with white clear indicators/bumper lights
and I added a "V8" emblem below the side indicator
+ the Jag center wheel emblem
XKR, side V8 emblem, clear indicators, Jag center wheel emblem mounted
Old Jul 3, 2017 | 04:19 AM
  #270
Salo's Avatar
Smile DIY - Nav to 3Gauge conversion - done, step-by-step photo's
Hi Guy's and Ladies,
share some experience from replacing my old crab Nav to 3Gauge,
the instructions from Steve ie TheJagWrangler where great I just got confused when it came to open up the main connectors for the main dash board ie
"pry off the hood retainer gently with a pair of pliers."
see me pic's below, it explains how these "hoods" are made and how to open them - if it helps someone who want to this by themself I be happy to share.
You need; 3Gague, Center wood piece, wiring harness, instructions+ patience
old Nav
Triple Check the Wiring !!!
XKR - 3Gauge - final result, Elm wood panel
Old Jul 23, 2017 | 09:47 AM
  #271
MRomanik's Avatar
Veteran: Air Force
Default 5HP24 dipstick
Finally got around to installing the trans dipstick from M Euro Sport. A real PITA when you don't have access to a lift and very little room to work. It was a real struggle for this 70 yr old.
After installing, I have a small drip where the tube attaches to the adapter. I may have installed the compression sleeve in the wrong direction.
Old Jul 30, 2017 | 04:53 PM
  #272
Default Get car up in the air with "handling package "
Last week I wanted to get my Black Cat up in the air to get wheels off to make them and Calipers spotless, before the big Jag show here on Vancouver Island.
The Car has The Handling Package so it's lower then normal XKR's.
My Floor jack was going to fit under but the Jack handle would not lift the car...just too low and no room.
So I decide to cut some 2X8s and make 4 ramps...drive the car up all at once so ALL 4 tires roll up at once. You need to have a few feet to get going ...inertia...but slowness is important, so the back tires don't scoot the 2X8 out behind the car..did that once.
Think I will glue thin rubber under the 2X8's next time as they tend to slide on polished concrete floor of my garage.
Now I can get Jack under the front... but in 2005 & 2006 there is no place from the front of the car to use a floor jack
Previously I watched Reverend Sam Video
Now I go online and got the jacking points from this forum https://www.jaguarforums.com/forum/x...-points-71240/ and find this
Back to the Garage... and get the front up and jack stands in place. You need to put the floor jack on an angle ...cup towards the engine to the lift point, handle under front door so you can get the jack stand just behind the factory jack lift point inboard of the rocker panel where there is solid metal .
Then tackle the rear...Drat! the Jack goes under and with a block of wood on Cup but now there is no room to pump it up....Double drat...hits trunk[boot] floor
So I put a piece of 2X6 under the front jack wheels[see arrow] and now I can pump it up using the Reverend Sam video... center point [three bolts] as there is enough room for short pumps as trunk floor is low
Car was in the air in about 2 hrs of trials and errors and on Jack stands!!
Old Jul 31, 2017 | 10:53 AM
  #273
Richxk8's Avatar
Installed a remanufactured ABS module from ASI this morning, great thing was I didn't get the Incorrect Part Installed message, no trip to get it coded to the car. Fixed all the issues. CEL "C1137 code", ABS Indicators and TRAC & ASC Not available Message, it is a good day.
Old Aug 6, 2017 | 05:22 PM
  #274
mhminnich's Avatar
Finally wrapped up a horrid water pump job on my daughter's car and decided it was time to bring the e-type out of a 10 year cold storage for some long overdue love. That's my son's 08 R in the background. The e-type type is his when f​​​​​​inally​ finished.
Old Aug 6, 2017 | 06:57 PM
  #275
GroovyMom's Avatar
I purchased a rebuilt throttle body from ASI and had it installed today. We had a glitch in removing the old one and a connector from the pedal position sensor disintegrated upon removal. Had to make a run to a scrap yard to find a replacement; that was installed today and the car is running great! Thanks to all who recommended ASI. Great service, reasonable price and they answered the questions of my friends who installed it for me. Thanks everybody! I'm a happy driver again.
Next up, hydraulic hoses..... Already got the new ones, just waiting my turn...
Old Aug 7, 2017 | 02:59 AM
  #276
joesoap's Avatar
Replaced front left wheel bearing, bought full hub from eBay and did a swap, will now replace the bearing in my original once my rotor nut tool turns up.
Interestingly once completed had a DSC/ABS fault showing till I realised the eBay hub was pre 2003 so had old non PWM sensor. Quick swap sorted it and my wandering front end is no more
Old Aug 7, 2017 | 12:46 PM
  #277
DevonDavid's Avatar
I set fire to my rear suspension.
Old Aug 8, 2017 | 10:47 PM
  #278
rothwell's Avatar
I removed and cleaned all my seat belts.
Thankfully no fires.
Old Aug 9, 2017 | 07:48 AM
  #279
joesoap's Avatar
Devon is it that cold in your area at moment try putting your heating on, Lol
Only in the UK do you have to buy a new tumble dryer in the summer.
Old Aug 13, 2017 | 10:49 PM
  #280
Jestocost's Avatar
Did full tensioners, water pump and thermostat. Thanks to my son who provided the knowledge and the tools.
