What is involved with reflashing a ecu?
Old Aug 21, 2023 | 08:08 PM
Lanny's Avatar
Default What is involved with reflashing a ecu?
I have a 2002 XK8 that I have purchased a replacement ECU for from a ebay source. As I understand it it needs to be matched to my VIN# before it will let me run it. It cranks, but won't start. What is involved to do this?
Old Aug 22, 2023 | 08:24 AM
motorcarman's Avatar
A replacement ECU for a 4.0 XK does not require REFLASH.
The VCATS needs to match and then an IMMOBILIZATION SETUP needs to be performed.
Old Aug 23, 2023 | 03:41 AM
Lanny's Avatar
That is wonderful news. Can you elaborate a little on how this is done? I am lost here.
Old Aug 23, 2023 | 09:01 AM
An IMMO SETUP is performed with WDS/IDS or similar diagnostic equipment.
SETUP and CONFIGURATION tab is selected and follow the 'onscreen-prompts' to get the replacement ECM configured to the vehicle CAN BUS.
mcpflrb
Aug 21, 2023 07:39 PM
AMC
Apr 21, 2018 11:06 AM
Thang Nguyen
Aug 28, 2016 10:42 PM
BaDAss03STR
Sep 10, 2008 02:57 AM
