What are these hoses?
Old Mar 25, 2020 | 07:21 PM
giandanielxk8's Avatar
Default What are these hoses?
Today, while I was finally getting around to adjusting my parking brake, I noticed a couple severely cracked hoses. The fact that they are dry leads me to believe they are from the emission's system? Could explain why a month ago I got a code for a gross evap leak? I thought it was an open gas cap, specially since it didn't return.
If someone knows what they're for, it would facilitate me searching for them in SNG's catalogue.
Here's a picture, for reference, that's the rear sway bar near the location of the passenger side sway bar bush.
Old Mar 25, 2020 | 07:43 PM
RJ237's Avatar
SNG Barratt US | CARBON CANISTER-SINGLE SYSTEM-WITHOUT RUNNING LOSS Assembly
It's one of the systems on this page
Old Mar 25, 2020 | 10:59 PM
Originally Posted by RJ237
Thanks RJ! It seems to be whatever hoses connect directly to the carbon canister, but from that diagram it is not readily apparent.
Edit, upon further researching, I think my car uses the Twin O.R.V.R. system.... I don’t really understand what the difference in function is.
Old Mar 25, 2020 | 11:36 PM
It seems that everywhere the price for one of them is over $170, and the smaller one is discontinued. I think I will just get a foot of whatever thickness of hose those are, cut and install. If I did choose the correct part numbers, the hose that has the 30º bend on it is attached to a metal pipe and has more hose on the other end. I have to figure out if both ends of the hose are bad and how much disassembly is required.
Spikepaga
Mar 14, 2020 06:53 PM
stevepaa
Aug 14, 2018 07:16 AM
greverrr
Jun 22, 2016 10:18 AM
chknhwk
Sep 4, 2010 03:21 PM
