What is towing eye-bolt thread size?
Old Sep 25, 2018 | 12:28 PM
car5car's Avatar
Default What is towing eye-bolt thread size?
I paid $12 for 3/4" eye-bolt from hardware store, it went in, but feels loose. Thread step is the same, it is probably 3/4"x10 thread. (what I bought). Can it be metric? M20x3mm???
Old Sep 25, 2018 | 12:47 PM
Jon89's Avatar
I believe there are different-sized thread patterns for different model years....
Old Sep 25, 2018 | 01:36 PM
motorcarman's Avatar
The early tow-eyes are M20 x 2.5mm RH thread.
The later ones are M16 x 3.0mm LH thread.
fmertz's Avatar
You need to search this site for "tow eye", and look through the results, like this one:
tow-eye-source-20-mm-134657
Old Sep 25, 2018 | 04:18 PM
car5car's Avatar
I used 3/4"-10 thread, it worked.
USA 10 thread is identical to metric 2.5mm
3/4" is 19mm, but original tow eye has 10 working threads, mine went in probably 20 turns.
I'll go to junk yard and check all Jags there. I go there anyway about twice a week.
Thanks for all responses.
Let me know about BMW, Mercedes and other European cars sizes please.
Old Sep 25, 2018 | 08:25 PM
Be careful with the tow eye under heavy load, like hauling up on a tow truck.
If your 3/4" (19mm) tow eye tears loose from your car then good luck with the repair bill.
The overall diameter is smaller (19mm vs 20mm) so it will likely strip out the hole/bolt and fail under heavy load.
"USA 10 thread is identical to metric 2.5mm"
There is no identical correlation between SAE and Metric. They might have similar dimensions but not IDENTICAL.
Make sure there is nothing behind the car when pulling it up on a flatbed tow truck.
bob
Old Sep 26, 2018 | 03:32 AM
car5car's Avatar
bob
USA 10 thread = 1"/10=25.4mm/10=2.54mm
USA 24 thread = 1"/24=25.4mm/24=1.04mm[ounojnozb
-------12-------------------------------------------2mm
Old Sep 26, 2018 | 03:55 AM
So you are saying 2.54 is identical to 2.5? Close but no cigar.
A 3/4" bolt will screw into a M20 nut it will also fail when stressed don't do it.
hnh375
Canada
Sep 25, 2018 12:34 PM
philwarner
Feb 2, 2016 10:54 AM
LeapingCat
Mark V - X 420G
Feb 22, 2014 12:39 PM
motorcarman
Sep 4, 2013 07:11 PM
TopHatChef
General Tech Help
Mar 4, 2012 02:06 PM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
