What's this?
Old Jan 21, 2021 | 10:10 PM
MFoncerrada8's Avatar
Default What's this?
Old Jan 21, 2021 | 10:26 PM
xalty's Avatar
vacuum res for the cruise control, only found on the 97-98 AJ26 engine. there should be a vacuum line going to the nipple
Old Jan 22, 2021 | 09:39 AM
michaelh's Avatar
or should do.
See this post from spuddyo:
https://www.jaguarforums.com/forum/x...07/#post674486
Old Jan 22, 2021 | 11:35 AM
Thank you all. That explains the issue I've had with my cruise control. I took car in for service a couple years ago and they must have broken the top of the vacuum reservoir and glued it back on!!! I started having issues with the cruise control working intermittently afterwards and finally saw the issue with that part when the vacuum line came unglued... I will search for a replacement. Thank you all.
Old Jan 23, 2021 | 11:47 AM
Markel's Avatar
Another reminder of if i couldnt do it myself i wouldnt own it
Old Jan 23, 2021 | 01:08 PM
motorcarman's Avatar
Way back in 2000 Jaguar warned us about broken stub pipes with a TSB.
Denial of warranty claims were not unheard of.
File Type: pdf
Old Jan 25, 2021 | 11:31 AM
Thank you for that info. If it warranted addressing it in that manner it must be a rather common problem. CHeers
Scottsgreenjag
Sights N Sounds
Apr 10, 2021 08:52 PM
Z07Brandon
XJ220
Aug 11, 2017 04:02 PM
Javier Mena
Europe
Feb 23, 2014 02:44 PM
PinnacleWax
Detailing / Car care
Feb 13, 2014 01:35 PM
Supralative
Jan 9, 2008 09:20 PM
