Where to buy shocks and parts
Old Dec 4, 2015 | 09:51 AM
perfectphoto's Avatar
Default Where to buy shocks and parts
I have a 2001 base XKR with 134k that I have done all the soft parts in the front end but I still have a clunk coming from the left front wheel. It looks like the shock might be leaking, just sure though. I want to replace the springs shocks and shock dampeners. I have a CAT system and not really want to spend $350 per shock to replace. Does anyone have a better option? Can anyone rebuild my old ones? Some help would be great. Also any though on where to buy for the best price?
Tom
Old Dec 4, 2015 | 10:10 AM
Jon89's Avatar
Try FCP Euro in Milford, CT. (877) 634-0063. fcpeuro.com.
Old Dec 4, 2015 | 10:36 AM
ccfulton's Avatar
Technically they could be rebuilt but this particular design is a crimped together body which Bilstein says is not servicable so Bilstein won't do it. You would have to find an independent shop willing to take on a challenge and it probably would end up costing more than new. I gave up and bought a set of CATS shocks from Gaudin in Las Vegas.
If you are not interested in keeping the CATS system, you can use standard non-adjustable shocks and unplug the controller in the boot.
There will not be any error messages with it unplugged but it will mean you have to do all 4 shocks at the same time. Although 4 regular shocks are hardly more expensive than 1 CATS shock.
Old Dec 4, 2015 | 11:45 AM
fmertz's Avatar
Have you changed the anti-sway bar bushings? They are on the "usual suspects" list for front end clunking. Cheap, and easy to replace.
Best of luck, keep us posted.
Old Dec 4, 2015 | 03:53 PM
brgjag's Avatar
Just did mine, shut the front end up. If not those could be sway bar bushings up there with the miles you have on the car.
I could not really find cheaper shocks and springs so I paid the piper to one of the site sponsors for spec ones for the front end.
Old Dec 4, 2015 | 04:29 PM
Yes I did change the sway arm bushings
Old Dec 4, 2015 | 05:12 PM
brgjag's Avatar
did sway bar endlinks? Sure it is not a ball joint?
Old Dec 6, 2015 | 11:05 AM
I replaced all the soft parts in the front end and sway bar links and shock bushings. When I bounce on the fender the shocks seem fine. No excess return bounce back.
Blue_XJ8
Dec 3, 2016 12:03 PM
WhiteTardis
Nov 29, 2015 12:24 PM
Alan DeFend
Nov 22, 2015 12:47 PM
essepi
Nov 19, 2015 07:49 PM
Alexv12
Nov 12, 2015 03:05 PM
