Where is the Ignition Module located on 2000 XK8?
Old Feb 9, 2010 | 02:23 AM
Bob0927's Avatar
Default Where is the Ignition Module located on 2000 XK8?
Title says it all - I am looking for the location of the Ignition Module for my 2000 XK8. Any help?
Old Feb 9, 2010 | 04:31 AM
test point's Avatar
The Engine Control Module is located in the 'firewall extension' on the right side (US passenger) within the engine compartment. The unit first visible is the Transmission Control Module. The ECM is the larger unit.
Old Feb 9, 2010 | 11:30 AM
Bob0927's Avatar
Thanks Test Point. So there is no separate Ignition Module? Is it contained within the ECM?
Old Feb 9, 2010 | 11:39 AM
Brutal's Avatar
Yes it is
Old Feb 10, 2010 | 01:31 PM
Bob0927's Avatar
Ok. Thanks. Good to know.
Old Feb 10, 2010 | 02:14 PM
Brutal's Avatar
Why do you want to know?
Old Sep 29, 2016 | 10:09 AM
JayJagJay's Avatar
Jumping into this thread...
All pictures I get in a google search shows two very different pictures of an "ECM" and an ignition control unit/module. In other descriptions it tells there are 2 of them. One for bank 1 and another for bank 2...? Then, that the ECM is something entirely different.
Is it a different set up in the 2000 and 2002 xk8?
Old Sep 29, 2016 | 10:47 AM
WhiteXKR's Avatar
The AJ26 engine through the '99 model year used separate ignition modules. Starting in 2000, the AJ27 engine had the ignition module integrated in the ECU. Introduction dates of the new engine might vary a bit based on the sales market.
Old Sep 29, 2016 | 11:07 AM
JayJagJay's Avatar
Hi. Thanks.
So, I have a 2002 XK8. Should or can I safely assume that my car (newly purchased an needing lots of love and attention) (and I have a LOT of learning to do) doesn't have the 2 separate units but one located and integrated in the newer ECU design?
I have lots of post (questions) coming... Lots
Old Sep 29, 2016 | 11:52 AM
WhiteXKR's Avatar
Hi. Thanks.
Yes, it is a safe assumption on a 2002.
Old Sep 29, 2016 | 12:43 PM
RJ237's Avatar
Welcome to the forum. When you have a question or problem, please start a new thread instead of hitching on an old one. In this case it was an exact fit, but often the original thread is somewhat different, and future searches may not pick it up to help a new member.
Old Sep 29, 2016 | 01:20 PM
JayJagJay's Avatar
Hi... Thanks!
Ask and ye shall receive... I just posted this in a new thread... Its a duzzy, so beware, lol...
https://www.jaguarforums.com/forum/n...5/#post1543552
Bcrary3
Sep 12, 2021 05:41 AM
XJsc-guy
Nov 23, 2015 01:56 PM
KarimPA
Sep 12, 2015 08:15 AM
jagent
Sep 12, 2015 01:40 AM
avern1
Sep 8, 2015 06:25 PM
