Where to send ABS Module for repair
I have a '97 xk8 coupe. My ABS module is bad, confirmed by dealer. I've read the posts on the topic and repair looks pretty easy.
Can someone provide reputable place to send module for repair?
Greatly appreciated!
Cherub40: I recently saw a couple of advertisements on EBAY for repair and refurbishment of ABS modules. Simply send yours to them, they repair and return. Go into EBAY, and search "Jaguar Modules".
Alternative: There is a company www.autoxpresstech.com that advertizies module repair. Hope this helps.
ModuleMaster
I was just about set to fix mine myself, but after looking over their site I decided the $100 was worth it. They attest to doing more than I would or could do and probably do a better job at it. Plus, Module Master gives a 5 Year warranty on their work. I believe a $2,500 OEM unit is only a one year - go figure.
While they have the module I'm going to replace the brake lines with stainless ones and replace the brake fluid.
Thanks guys very helpful. Next question. Once module is removed I assume you need to be bleed the brakes. Can anyone point me to a post or have procedures on to how bleed brakes?
ATE:High Quality Rebuilds at Exceptional Pricing
Someone here suggested these folks to me. I used them to rebuild the main computer on my 97 XK8, that was 4 months ago and the unit is working great. They have been around since the 90's.
ericjansen
Dec 19, 2021 12:20 AM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
Oct 12, 2015 11:56 AM
