Why
Old May 2, 2015 | 02:04 PM
Ivor4ever's Avatar
Default Why
Why do my windows keep loosing memory ??????????
Old May 2, 2015 | 02:25 PM
tsuppari's Avatar
Poor battery?
Old May 2, 2015 | 02:27 PM
jimforrest (uk)'s Avatar
They're old ............... like me ...................... what do you expect?
Sorry ........... what was the question?
Oh yes ................ Dunno!
Old May 2, 2015 | 02:30 PM
Just remembered - the only thing that kills the memory is power loss. Check and wiggle fuse, remove and replug relay(s) and check/wiggle connections to control unit. As tsuppari says it could be a (very) low battery.
Old May 2, 2015 | 02:46 PM
Ivor4ever's Avatar
Will try connections and have battery checked always starts engine "????????
Many thanks
zecretw's Avatar
If the battery is bad it will drop too low during cranking and it will lose memory.
Is the memory lost Before you start the Engine aswell?
Old May 2, 2015 | 04:09 PM
Ivor4ever's Avatar
Don't think so might be battery sounds expensive its a jag only the best for her
Old May 2, 2015 | 04:55 PM
batroute's Avatar
Losing the window memory is often the first sign of a dying battery on these cars.
Old May 2, 2015 | 05:28 PM
Kevin D's Avatar
I don't suppose that they have an Auto Zone or a Walmart in Bolton Cumbria, but perhaps there is some sort of auto parts place that can run a test on your battery. That should tell you if it is, in fact, the battery that is causing the problem. Good luck, hope it all turns out well for you.
Old May 2, 2015 | 07:43 PM
batroute's Avatar
Halfords in the U.K. will test batteries just as Autozone/Advance/Walmart do over here.
Old May 2, 2015 | 08:03 PM
Failing battery is probably the culprit, but worth checking as always.
Has the battery ever been changed or still on original Ivor??
If original it owes you nothing and best to change it anyway before she leaves you stranded
Old May 3, 2015 | 03:16 AM
Ivor4ever's Avatar
Prob original no bills in history
Being a jag is it just a normal swap ??? Am a mechanic but served my time in seventies
No computer in my day
Old May 3, 2015 | 03:40 AM
cjd777's Avatar
Ivor, it does need the right size battery with a vent hole. There is a hole in the top rail that a small plastic connector goes into. No big deal as most BMW and the like have this type of battery.
Wayne
Old May 3, 2015 | 04:05 AM
If it's the original battery, it will be a Varta in a UK spec vehicle.
The manufactured date is stamped on the top of the negative terminal:
The code is WW-YY so this one is Week 23 in 2012.
When you disconnect the battery you will lose 'learned' settings. The main one is the window limit switches. To reset them, raise the driver's door window fully and hold the switch until you hear a soft click after a few seconds. Next lower the window and again hold the switch until you hear a soft click. Repeat for the passenger window.
Old May 3, 2015 | 08:53 AM
lsimon's Avatar
Default AGM battery is a good replacement
I always find that when the battery becomes suspect it is best just to replace it. Testing seems very dependent on what testing equipment the place has and hasn't always told the whole story for me.
I'd had a few issues with the OEM Jaguar batteries over the winter when my XKR isn't used for long periods. Leaking and cracked batteries. So a few years ago I went to Sam's Club and bought an XGM battery. These do not vent as they are sealed and from what I've read hold a charge better and don't have the tendency for winter problems as the non-sealed batteries did. It's worked wonderfully the past few years.
This was more expensive than a standard battery at around $160 vs under $100 for a regular battery at Sam's Club (not sure they have these in the UK but similar to Costco)
Old May 4, 2015 | 01:25 AM
Ivor4ever's Avatar
Thanks all trip to battery supplier I think
Old May 4, 2015 | 04:25 AM
multiplecats's Avatar
Had this on a Ford Focus a few years back. Engine would crank/start OK but instrument panel lost it's brains and the speedo stopped working. New Battery cured it straight away.
