Will 1998 headlight assembly fit on a 1997?
Old Sep 24, 2019 | 01:47 AM
TheBaltimoron's Avatar
Default Will 1998 headlight assembly fit on a 1997?
Just want to make sure there's no sneaky difference before buying it. Also seeing some specifying Xenon or halogen, and some talking about with or without washer. Were these options? Thanks!
Old Sep 24, 2019 | 02:16 AM
DavidYau's Avatar
Default Not sure what you're planning - just some thoughts
Baltimoron,
Well, I've always had similar questions - will later part fit - when buying new bits for my Gen1 1999 XK8. I don't have a definitive answer to your question, but I would look closely at what you have first before you buy.
Not sure exactly what you're trying to do, but FYI you can get the front half lense unit separately from DCR (a lot cheaper than whole new headlamp unit.)
There is also a modification to avoid the common condensation issues (drill hole on inside and attach little rubber T piece.)
I attach a few pics below of when I did it on my 1999.
View of headlamp with front half removed. The Power wash is marked. You can check what connectors you have too behind the light bulbs.
Little T piece modification to vent the headlight unit to prevent condensation. Easier to fit with unit out.
My final result!
Heather2812
Sep 29, 2012 07:26 AM
Dave
Nov 29, 2010 01:40 PM
