Window alignment - Regulator Was Loose
Old Jan 13, 2019 | 09:49 PM
Johnken's Avatar
Default Window alignment - Regulator Was Loose
Someday this may happen to someone else so I wanted to report it.
passengers window had a gap between inner glass and rubber seal on quarter window. Pulled the door card, all looked good. Found the window was loose in that it wiggled a bit. This caused intermittent misalignment with rear seal.
I was searching for the cause, everything was right and tight, then I checked the regulator screws. Each one was equally loose! Tightened them up and problem solved.
I put a new regulator in about 2 years ago. Guess I didn't torque them to the 12ft lbs required.
Just wanted to add it to the list of quirky things that can go wrong for future reference.
John
Montru
Oct 24, 2017 06:38 PM
car5car
May 20, 2014 10:15 AM
Spikepaga
Sep 13, 2013 11:35 PM
Oct 28, 2010 11:12 AM
jagxkrtoofast
May 10, 2010 08:42 AM
