Window drop and top
Old Sep 23, 2013 | 09:28 AM
mapatton's Avatar
Default Window drop and top
Have something odd that has now happened a second time. When the top was going back up, the windows did not drop. First time happened about 2 months or so ago. It happened again yesterday. When this happens, the top will not lock. I lowered the windows and the top locked.
The top gets dropped/raised about 6 times a week.
Have not had any issues with the windows dropping upon entry/exit of the vehicle.
Thoughts?
Old Sep 23, 2013 | 10:44 AM
test point's Avatar
The window system is very sensitive to low voltage and can loose memory much below 12v. Operating the top, which is a pretty high current draw, with the engine off or at idle may be pulling a weak battery's voltage down to a point that the windows are confused.
I would suggest a free battery load test at you friendly local auto parts store might be in order. Can't hurt, doesn't cost much.
Old Sep 23, 2013 | 10:47 AM
Jon89's Avatar
Agreed. With any strange window issues, the first item to check is always the battery....
Old Sep 24, 2013 | 09:00 AM
mapatton's Avatar
Thanks I will check it out.
Both times the car was running.
Old Sep 24, 2013 | 09:18 AM
WhiteXKR's Avatar
If the battery is not up to snuff, the voltage can dip quite low during the heavy load of starting, causing the electronic controllers to get hosed up. The door module controller is the most suscepible to this.
99xk8guy
Sep 29, 2025 10:51 PM
bamforp
Aug 14, 2024 05:36 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
