window problem 04 xkr coupe
Old Nov 3, 2010 | 07:22 PM
protech's Avatar
Default window problem 04 xkr coupe
Just bought got the above, noticed that when you open the passanger door the window drops down to clear that's working ,but, if you keep opening and closing the widow keeps dropping and does return to up position when closed like drivers side.
Any ideas?
Bob
Old Nov 3, 2010 | 08:04 PM
H20boy's Avatar
If you don't have an owner's manual, try the FAQ thread at the top of this sub-forum. There is a link in there to download one.
You simply need to reprogram your windows, this is required after every battery disconnect, or one of the first signs your battery is dying.
Sit in the car, close the door. Hold the window switch down till the window drops all the way, then hold...you'll hear a click in about 3 seconds. Now roll the window up and hold again at the top...another click. That window is now programmed.
Old Nov 4, 2010 | 07:15 AM
protech's Avatar
Default xkr window problems
Just did as directed and it worked!
"I love it when a plan comes together"
Thanks for your help.
Bob
Old Nov 4, 2010 | 08:42 AM
H20boy's Avatar
Glad to have helped, that was an easy one compared to most questions. If you read the FAQ thread you'll see the other more popular topics of discussion, with many being solved by our resilient and intelligent members.
toronadomike
Jan 22, 2026 10:13 PM
Beardy
Sep 18, 2015 10:00 AM
alpecsa
Sep 7, 2015 11:55 AM
David Thompson
Sep 3, 2015 07:48 PM
TC Johnson
Sep 2, 2015 09:30 AM
