Window up/down on opening questions
Old Dec 20, 2014 | 07:32 AM
TreVoRTasmin's Avatar
Default Window up/down on opening questions
So my 97 seems to be loosing its memory about ever 10-20 door openings, Drivers side still going down but will go down more when you shut the door or pull on the door handle again when the door is open. Pass side will less frequently not go down. Resetting works for a day or so then issues return. Have sprayed electrical cleaner into both latch mech. but no real change. Anybody solve this issue? If so how? I do have a parts car but these look like a pita to r&r.
Old Dec 20, 2014 | 07:40 AM
how old is the battery?? I would have the battery & charging system checked first
Old Dec 20, 2014 | 07:46 AM
K.Westra's Avatar
I agree on the battery. The window memory is one of the first signs of low voltage. Check to make sure the battery contacts are clean also.
Old Dec 20, 2014 | 07:57 AM
Battery is just fine, 2 years old but shows 13.2v when sitting. Connections clean and free of corrosion. Will still do even when plugged into my battery tender btw.
Old Dec 20, 2014 | 09:08 AM
WhiteXKR's Avatar
You need to check the battery voltage after the surface charge is dissipated and the engine is off. Let the car sit overnight without the battery tender, then check the voltage BEFORE starting the engine and without connecting the battery tender.
Old Dec 20, 2014 | 12:18 PM
13.2-12.9 if its sat for an entire day, just where a good battery should be. If I thought for a minute it was a battery issue I'd swap between the xjr and the xk8 but I've already explored that. Wish it was that simple and both the window issue and the abs stability fail would go away with a 100 battery but I'm not a lucky guy.
Old Dec 20, 2014 | 02:18 PM
BobF's Avatar
Try measuring the voltage at the fuse block behind the spare tire. Could be a positive cable problem.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
fingers
General Tech Help
Oct 21, 2015 02:02 AM
James007
Sep 6, 2015 06:47 PM
