window washer pump
Old Aug 28, 2017 | 01:28 PM
macjag1745's Avatar
Default window washer pump
First post ,I dont know the rules ,anyway I have a 1997 xk8 ,and unfortunately I have a problem with my window washers the pump is not getting any electricity I have a friend who is a part time mechanic But he doesn't know a lot about Jaguars he's had a look but he has no idea what he can do to repair the problem ,can anyone out there help me please.
Old Aug 28, 2017 | 04:26 PM
pbuck's Avatar
According to circuit diagram:
Fuse #7 30Amp
In engine compartment fuse box
Powerwash relay is in there, too
Try those first.
Old Aug 28, 2017 | 06:16 PM
Originally Posted by macjag1745
First post ,I dont know the rules ,anyway I have a 1997 xk8 ,and unfortunately I have a problem with my window washers the pump is not getting any electricity .....
Welcome to the forum macjag1745,
You may not know the rules but you found the right place first time to post your question which is more than many newbies manage to do.
Pump not getting electricity - is this confirmed by taking off the wheelarch liner and checking the harness connection to the pump in the screenwash reservoir?
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Aug 29, 2017 | 04:56 AM
macjag1745's Avatar
Default Windscreen washer no electricity
I'm still trying to figure out how the site works ,how to reply etc ,so forgive any errors please .
yes I think he tried that ,he also informed me that he had checked all the fuses in the car
Old Aug 29, 2017 | 05:00 AM
macjag1745's Avatar
Thanks a lot I'll inform him this afternoon,
Old Aug 29, 2017 | 05:53 AM
Here's the circuit diagram:
Now you've eliminated fuses, if the pump will power directly then the next possibility is a faulty wash/wipe stalk.
Old Aug 29, 2017 | 10:27 AM
macjag1745's Avatar
Thanks for the diagram, could you tell me how to check the wash /wipe stalk ,the wipers are working fine as are the 2 pumps when powered directly so I think you may be right
Old Aug 29, 2017 | 10:43 AM
macjag1745's Avatar
Another question perhaps a little foolish to you experts out there but how do I identify the relay I'm looking for and can it be tested ?
Old Aug 29, 2017 | 01:11 PM
macjag1745's Avatar
which one is the powerwash relay they areall identical and there are 7 or 8 of them in there
Old Aug 29, 2017 | 01:50 PM
michaelh's Avatar
Powerwash relay is here:
Just a thought - do the wipers cycle when you pull the stick forward? If so, it's probably OK.
Old Aug 30, 2017 | 03:37 AM
macjag1745's Avatar
Default windscreen washers
Thank you Micheal h,I think the wipers are working ok but I'll try them again,just no power getting to the pump ,is there a way of testing the relay?
Old Aug 30, 2017 | 03:59 AM
macjag1745's Avatar
I've just tested the stick by pulling it forward ,wipers cycle but nothing else,still no power getting to the pump
Old Aug 30, 2017 | 06:57 AM
michaelh's Avatar
Sorry - brain freeze. What I meant to say was 'do the wipers cycle when you press the button on the end of the stalk'
There's a similar thread here by spuddio that he tracked down to F7 (15A) in the drivers facia fusebox, but he had other issues also:
https://www.jaguarforums.com/forum/x...30/#post680469
Failing that, it's a case of tracing the wiring from the pump back through connector LF1 to the body processor module. One other possibility is the grounding to the stud LF1AR (shown in GGG's diagram). JTIS shows it adjacent to the RHS headlamp.
Old Aug 31, 2017 | 06:53 AM
macjag1745's Avatar
Default windscreen washer pump
I have checked the number 7 fuse 15 amp driver's side facia it's ok I also checked the fuses in the engine compartment number 7 30 amp its ok as well ,neither the windscreen washer or the headlamp washer is working ,the wipers seem to function correctly,even when I press on the button at the end of the stalk they cycle as they should do but als no liquid to be seen anywhere, as we say in France "a l'aide" I don't know how to check the relay "powerwash " how does one check a relay?
Old Aug 31, 2017 | 09:25 AM
grantorino62's Avatar
All brown relays are the same. Swap relays. On my car, at least, the headlights have to be on to have the headlight washers function.
Old Sep 1, 2017 | 07:52 AM
macjag1745's Avatar
Default Wash wipe relay
Thanks for that I'll try that this afternoon
Old Sep 2, 2017 | 06:28 AM
macjag1745's Avatar
I changed the relay in the engine compartment (exchanged with another relay )and the headlight washers seem to be working,but still nothing with the windscreen,any sugestions anyone ?
Old Sep 2, 2017 | 06:32 AM
macjag1745's Avatar
could you tell me exactly where the stud is situated and what it looks like michaelh,sorry but I'm a complete novice so I don't have a clue really
Old Sep 2, 2017 | 09:07 AM
Johnken's Avatar
You know, something just occurred to me. I've seen several wires solder joints come lose and disconnect with age on the end of the headlight stalk. I would imagine the price of a new wiper switch is just as shocking as the headlight is.
Given that you may want to pull the steering wheel and have a look. Ok stick with me here: I was about to delete this suggestion thinking if the wipers cycle, the momentary switch is sending a signal to start the was cycle. Who would design a switch with 2 separate wires to start this automated cycle?
I am on a phone without glasses so can't review thediagrams. Since this event (squirt, wipe, wait wipe) is a coordinated layered event it must be managed by a module.
I think we may have just proved your switch and it's wires are ok by the fact that the wipers energize. I don't see how the switch would have 2 separate wires but do check the diagram to be sure.
My next step would be to read "trigger" voltage at the relay for the pump while someone presses the button. If no voltage present, provide some to ensure the pump works.
John
Old Sep 2, 2017 | 09:28 AM
macjag1745's Avatar
John
Thank you for your post even though I'm having problems understanding it,on which diagram could I check if the switch has 2 separate wires or not and where do I find "trigger" voltage,I must admit to being a complete novice in car electronics,or indeed electronics in general.
