Winter is coming in Cin, Oh what oil...
Old Oct 7, 2009 | 06:22 PM
brgjag's Avatar
Default Winter is coming in Cin, Oh what oil...
should I use. I use Mobil 1, what should viscosity I quess it is called in it? 5w40, 10w30, what ever those numbers are, what one should I put in the car this winter.
Old Oct 7, 2009 | 06:59 PM
K.Westra's Avatar
I suggest 5W30.
Old Oct 7, 2009 | 08:22 PM
Thermo's Avatar
Veteran: Navy
brgjag, because you have a 97 Jag, for winter, use of 5W30 will be the best choice. Thick enough to coat the surfaces well but not so thick when it is cold that it can't flow easily. If you had a new car, then that would be a different story. The newer motors have even tighter tolerances and require a different grade oil.
Old Oct 7, 2009 | 08:29 PM
brgjag's Avatar
thanks folks! What should I have been running this summer??? Just curious as the shop changed the oil when they did the tensioners and I do not recall what they put in it other then it was Mobile 1.
dsnyder586
Dec 29, 2024 07:39 PM
GordoCatCar
Jan 2, 2017 01:10 PM
redrover41
23
Sep 25, 2015 01:33 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
James007
Sep 6, 2015 06:47 PM
