Winter Wake Up
Old Jan 10, 2015 | 03:03 PM
rperformance's Avatar
Default Winter Wake Up
One of my Winter Storage precautions is to turn the ignition on every few weeks to get the fuel pump to cycle the check valve. That times out after a second without starting. Sitting in the car today where it's warm and quiet I could hear what sounds like the fan blower motor on very low speed from the passengers side seat. The Climate Control and blower were turned off. When the key is turned off the sound goes away.
My question is ... it this normal or is something amiss? I just never noticed it before.
Old Jan 10, 2015 | 03:11 PM
jimmiejag's Avatar
I've noted the same fan-like noise from the same area in my 1999 XK8 when I turned-on the ignition to check the ELM327 and Torque Lite app that Santa brought me.
Climate control was off, too.
Old Jan 10, 2015 | 05:50 PM
Paul Pavlik's Avatar
Cooling Fan for the ECM?
Old Jan 10, 2015 | 07:34 PM
TreVoRTasmin's Avatar
Curious to me is why do you do it? I'm one who is the leave it sit kind of guy and haven't been convinced otherwise (even with something as modern as an xk that shouldn't need a darn thing aside from a tender). Got my popcorn and studious glasses out as once you stop learning you should lock the casket door.
Old Jan 10, 2015 | 08:50 PM
Just for fun search around sometime about fuel pump filures on cars that aren't driven reguarly. You can let yours set. 20 seconds of PM seems like time well spent VS a fuel pump replacement at 10 percent of the vehicles worth. Besides that I get to smell the leather during the cold long winter.
Old Jan 10, 2015 | 08:52 PM
I wasn't aware that it had an ecu fan but sounds like something new to learn.
Old Jan 11, 2015 | 12:39 PM
The Supercharger Coolant Pump will also come on with the Ignition, but it is located in the Engine Compartment, under the Air Box.
Old Jan 11, 2015 | 01:15 PM
Chuck Schexnayder's Avatar
I would think that Jaguar has to comply to all US safety features to be able to ship cars to the US, but I may be wrong.
However, and I don't know when it became law--if it ever did--but a US automobile has to have "Positive Ventilation " features. This means that when the ignition is in the on position, engine running or not, the ventilation system (interior fan) must come on, however slight.
I'm sure that if you place you hand over the vents--maybe top or bottom--you should feel a very slight movement of air coming into the car.
What that does safety wise, I have no idea. There may be people who sit in their car , listening to the radio for long periods of time and lingering fuel vapors could be harmful. ????
Old Jan 16, 2015 | 10:20 AM
Thank for the idea on possative ventalaition. I bet that's what I heards going on inside the dash with the key on and Vent off.
Larry-Cleveland
Feb 9, 2019 03:17 PM
Delta66
Oct 4, 2015 05:40 PM
Jässe in Pälkäne
Oct 2, 2015 05:38 AM
Malihide
Sep 29, 2015 03:21 PM
black5litre
Sep 27, 2015 03:10 PM
