wishbone eccentric
Old Mar 20, 2014 | 11:38 PM
stevepaa's Avatar
Default wishbone eccentric
So I searched severall threads and could not find how to remove the lower rear bolt on the front wishbone. The sterring rack gaiter blocks the path .
Do I drop the steering rack?
Old Mar 21, 2014 | 01:52 AM
Domingo's Avatar
Yes and no. I just moved it far enough to remove the bolts so as to replace them with the eccentric bolts. By removing the steering mounting bolts only.
Old Mar 21, 2014 | 09:18 AM
stevepaa's Avatar
Did you then push up or pull down? thanks
Old Mar 21, 2014 | 09:52 AM
RaceDiagnostics's Avatar
Let the steering rack droop down, turn to full luck and gently tap out the bolt.
thedugger1
Oct 16, 2015 10:18 PM
Fraser Mitchell
Oct 1, 2015 04:06 AM
TreVoRTasmin
Sep 18, 2015 06:57 PM
sonofdave1980
Sep 14, 2015 07:45 PM
Laleekiraly
XJ40 ( XJ81 )
Jul 4, 2010 01:25 AM
