Hi everyone,
I have a 2002 X100 that I haven't started in a while. The car is turning over but won't start and I believe its the immobilizer.
Thanks in advance.
- The remote locking isn't working. I have replaced the battery but has made no difference.
- I have tried to reprogramme the key but the red light by the gear stick does not blink.
- Only the door that I insert the key into will lock (central locking seems to be out)
Thanks in advance.
JagV8
close
- Join DateMay 2009
- LocationYorkshire, England
Liked:4,902 Times in 4,226 Posts
If it's the immo I'd expect a code saying so and possibly also a PATS flash code. (But I'm not 100% sure you have PATS at that era car - someone hopefully will say.)
DavidYau
close
- Join DateJan 2019
- LocationBahrain
Liked:1,427 Times in 759 Posts
Dlaregztif,
I would attack the power issue first. You say car has been sitting for a while. So you switched out the car battery. Is it still running a strong 12.7V or more? Does the starter crank strong?
Central locking isn’t working which is a clue. Do you have a black key (not the green valet key)?
Try this - Hold the key in the on position (don’t start) and wait until car has gone through the start up checks. Then off. And then try to start.
Lots of other possible problems before you start checking for spark and/or the KTM module. Fuel pumps going out after standing for a while is common.
Quote:
I had a look but can't seem to find any info. Seems to be in the 2003 model though.Originally Posted by JagV8
I'm not getting any red light on the J gate either so might not be the immob
Cranks as normal, full charge on the battery. Originally Posted by DavidYau
Dlaregztif,I would attack the power issue first. You say car has been sitting for a while. So you switched out the car battery. Is it still running a strong 12.7V or more? Does the starter crank strong?
Using the black key, I don't have the green one. I've been starting like that, waiting for the lights to go out before starting and it just won't start.
I'll check the fuel pump in the morning.
RJ237
close
- Join DateDec 2010
- LocationDouglasville Ga.
Liked:2,920 Times in 2,316 Posts
Do you have fuel pressure with the ignition on? If yes, try shifting to neutral and see if it starts. It could also be bore wash.
