Worth changing v2 for v3 secondary tensioners
Old Jan 18, 2026 | 04:36 AM
pcock111's Avatar
Default Worth changing v2 for v3 secondary tensioners
I have a 2005 XKR X100. It has done 95k miles. I understand it was factory fitted with v2 tensioners and that v1 was the version with cracking issues. My question is: was there also an inherent fault in v2 in order for jag to upgrade to v3 and should I change mine out? Thanks.
Old Jan 18, 2026 | 08:04 AM
motorcarman's Avatar
Version 2 secondary chain tensioners were a 'stop-gap' measure. They were simply a spring added to keep tension on the chain until the oil pressure 'came-up' and pressurized the tensioner.
They were abandoned in 2001/2002 and the aluminum bodied units were introduced.(version 3)
NO 4.2 liter engines were fitted with ANY of the 'problem' tensioners!!!!!!!!!!!!!!!!!!!!!
Old Jan 18, 2026 | 08:15 AM
dibbit's Avatar
This guy has the exact same problem as you. You should swap notes.
https://www.jaguarforums.com/forum/x...cement-294312/
Old Jan 19, 2026 | 04:48 AM
pcock111's Avatar
Old Jan 19, 2026 | 09:36 AM
Why are there 2 threads on the same subject.
Can the 2 be MERGED?
asjdhsajhdfj
Jun 25, 2025 09:31 PM
MFoncerrada8
Nov 19, 2017 04:06 PM
JagXK82001
Mar 30, 2011 08:54 AM
graycobra
Mar 20, 2010 01:06 PM
wilson18067
Jul 22, 2008 06:54 PM
