Would like some thoughts on worth of a 2000XKR
Old Sep 13, 2019 | 12:23 PM
htrdlncn's Avatar
Default Would like some thoughts on worth of a 2000XKR
I would be buying this as a project to didle with on my off time,
I have shop and can work on my own stuff,,however this particular car doesnt run,
It is a 2000XKR convertible, has 80000 miles and owner hasnt driven it in 6 years, top doesnt work either,
he is asking 5500US , There are a few running XKRs for same price that are running in my area
but they all have 150000 miles or more. SO my question to you all is this car worth $3500(what im thinking of offering)
in parts in case the drivetrain is completly shot? By milage Im thinking he broke te timing chains and
thats why he doesnt want to start it.
Just want to know I can recoup my money even if its a big dud.
The pictures are from when car was still running which was over 6 years ago so Im sure it doesnt look this good any longer.
Thank You for your time!
Old Sep 13, 2019 | 12:26 PM
htrdlncn's Avatar
One last thing,,is it just me or did the rear of this car look too high compared to other XKRs?
Old Sep 13, 2019 | 12:35 PM
htrdlncn's Avatar
Old Sep 13, 2019 | 12:50 PM
fmertz's Avatar
Yes, the front suspension looks collapsed. Likely the upper mounts. Not a deal breaker, but likely brought in excess negative camber and may have ruined the tires if uncorrected for too long.
PS: A car not started in 6 years will likely have major fuel system problems with gummed-up injectors, pump, regulators, etc.
Old Sep 13, 2019 | 12:58 PM
htrdlncn's Avatar
thanks,yes I figure every line (fuel,hydraulic,brake,etc) will have to be removed and cleaned out.,
My main thought is there enough parts I can sell to recoup my $3500 if it turns out to be a lost cause?
I know what the cars sell for from looking over last few months but not so much the parts.
Old Sep 13, 2019 | 01:15 PM
Jon89's Avatar
I would want to know exactly why the car has not run in six years. If the engine is indeed trashed, you are looking at some very high-dollar replacement costs. How much maintenance and repair history can the current owner show you? Having access to all service records is extremely valuable in cases like this....
Old Sep 13, 2019 | 01:29 PM
htrdlncn's Avatar
Im going on the assumption engne is thrashed.Even if its not I would be pulling it anyways
to go thru it,do timing chains and clean everything out.
Again my question : IS there 3500 in parts I can sell if the engine and running gear are thrashed.
Meaning can I sell the body parts and whatever else is salvagable and recoup my $3500..
Thank You.
Old Sep 13, 2019 | 02:27 PM
EnjoyEverySandwich's Avatar
If not $3500, I'd imagine it'd be pretty close. Comes down to how much time you want to spend disassembling, sending things out, waiting for people to bite etc. Random rare parts would be worth quite a bit on top of the usual body/interior bits.
For precisely the same reason, even if the drivetrain isn't toast, this would still be an expensive endeavor.
Old Sep 13, 2019 | 02:36 PM
htrdlncn's Avatar
I part out cars pretty reguarly,, this year a Explorer that guys son blew the motor,last year a Lincoln Mk8 the guy wrapped around telephone pole,,also part out boats,,Im a contractor so I supplement my income when I have no work, Id like to fix it but if its too far gone
then Ill part it out. I may just park it in my shop and wait till I find a good parts car for it.. I have some knowledge on what I can get off parts for American cars but not so much the Jag.
Guy might not take my offer so there is that as well
Old Sep 13, 2019 | 03:12 PM
That guy should take that offer. $5500 for an example that doesn't start is too high.
But, yeah, you could get solid money parting it out. It might take a while for people to bite, but there are definitely some stupidly expensive pieces on these cars. On my car, I had to have the crankshaft pulley replaced. That part, new, is like $1800. I got it a refurbed one for like $400. Stupid.
Wheels will be worth a good amount. Double-fives are nice.
If the undertray is intact, that's also a rare and expensive part.
Wood trim is hard to come by, so if that's in good shape, it'll fetch a good amount.
Body will get you a good chunk of the way.
Old Sep 13, 2019 | 04:53 PM
htrdlncn's Avatar
Thanks.. Thats what I needed.
Again,,its not my first plan,,just a backup ..
Sexy looking car and for me a convertible has to be bright red,
Old Sep 13, 2019 | 05:03 PM
Diddion's Avatar
Default Body condition
Body condition looks outstanding and it has suspiciously perfect paintwork for a 19 year old car, as far as I can see from the pictures. This could be a significant plus point, but it could also suggest some dodgy dealing. I would want to check this out very carefully, in case some paint has been blown over a rustbox, which might also hide other mechanical problems, causing an unsuspecting buyer to be wooed by the (possibly very temporary!) beauty of the car. And I would like to know where the car has been kept, as some of those pictures appear to have been taken on public roads, in which case, how did the Jaguar get there?
Maybe the car has not been run for 6 years, for legitimate reasons, or maybe it is full of unknown gremlins, which might both increase the cost of putting this right, and reduce its value for parts. I would be extra cautious on this one.
150,000 well maintained miles would be more attractive to me than 80,000 miles and 6 years fallow. During the well maintained miles, many component which wear and other components which deteriorate with age (whether or not used) are likely to have been replaced, and a good service history would encourage me to go for that higher mileage car.
Old Sep 13, 2019 | 05:51 PM
cjd777's Avatar
A candidate for the LS1 change over.
Good write ups and lots of kits help to get this done.
Old Sep 13, 2019 | 05:55 PM
htrdlncn's Avatar
If I did that I would do a 302 Ford,,not as powerful but a lot more compact
and easy to shove in small spaces.. I love the LSx but in the older Jags size is a considration
Old Sep 13, 2019 | 06:20 PM
cjd777's Avatar
You might want to read about the kits. It has all the Jag bits on a plug and play change over. All gauges working is a big deal if you are going to change anything to a different drive train.
Old Sep 13, 2019 | 07:08 PM
htrdlncn's Avatar
cjd777
you have links?
Old Sep 13, 2019 | 07:18 PM
CorStevens's Avatar
if the engine can be turned over by hand with the plugs removed and a good body shop gives it a very good condition rating, it is a desirable car to be fixed. 4.0 XKRs are valuable if not previously wrecked or rusted out.
Old Sep 13, 2019 | 08:35 PM
DavidYau's Avatar
Default Andrew from Jaguar Specialities is your man for LS swap
cjd777
you have links?
Check out the link below.
Jaguar Specialties
Old Sep 13, 2019 | 08:41 PM
cjd777's Avatar
Do a search for LS1 Jaguar Specialties and that should get you lots of reading.
I must admit that Whitehat is correct, if the engine is just a head job for a couple of bent valves, worth the effort to go in and fix it.
The top could be matter of hoses, which is not that bad a job to someone like yourself.
Just thought I would let you know, these are beautiful cars and hate to see one broken up in that, what looks like good condition.
Keep us up to date and ask for any help, some one has done it all.
Old Sep 13, 2019 | 08:53 PM
crbass's Avatar
LS7 is an option here. With ~30% more torque and ~40% more hp than the original, would probably be 'peppy'. In the xk8, with about 60% more torque and 75% more hp, perhaps buy stock in rear powertrain components and tires. And earplugs.
Fascinating.
