X100 MAF sensor access
Old Feb 28, 2025 | 12:58 PM
OCJoeR's Avatar
This is the live data I was getting. The first series were about 2 weeks before the second series:
Upstream O2
B1-S1 -0.490 0.290 mA
B2-S1 -0.127 0.124 mA
Downstream O2
B1-S2 0.095 0.210 V
B2-S2 0.435 0.705 V
Fuel Trim
Short Term B1 1.6% 8.0%
Long Term B1 7.0% 7.0%
Short Term B2 1.6% 8.0%
Long Term B2 9.4% 9.4%
2/11/2025
Fuel Trim
Short Term B1 -1.60% 0.00%
Long Term B1 4.70% 4.70%
Short Term B2 -0.80% 0%
Long Term B2 6.30% 6.30%
MAF .6 lb/min 1.9 lb/min
Lambda
B1-S1 1.004 0.997
B2-S1 1.009 1.045
Old Feb 28, 2025 | 02:14 PM
Y2KJag's Avatar
Upstream O2
Downstream O2
B1-S2 0.095 0.210 V
B2-S2 0.435 0.705 V
Fuel Trim
2/11/2025
Fuel Trim
Lambda
B1-S1 1.004 0.997
B2-S1 1.009 1.045
Interesting. I get much the same downstream voltages as you're getting. Constant fluctuating from 0.0 to 0.9, and all numbers in between, every second. By contrast, I connected the monitor to one of my BMWs, and downstream voltage was very steady, alternating between 0.65 to 0.75, which I understand is the correct behavior.
Also, LTFT at speed are at -10.2% and -8.7%, Band 1 and Bank 2, respectively. Indicating rich mixture. We'll install a fresh set of injectors this weekend and see if the LTFT numbers improve.
EZDriver
Nov 30, 2017 05:15 PM
EZDriver
Oct 18, 2017 05:58 PM
Daim
May 17, 2016 08:58 PM
EZDriver
Feb 11, 2016 08:17 AM
jtp2
May 25, 2012 08:47 PM
