X125 anyone? Only £1500, if you're quick.
Came across this 1997 X100 XK8 which has had a 'X150 facelift'.
Just needs a bit of tidying
1 day left and current bidding is at less than £1500.
My thoughts as well Graham.
If indeed the owner is a body guy as he states, doesn't look like that much more time and effort to finish the project.
To bad he also doesn't realise that it would take less than an hour to fill the gearbox up from start to finish.
Just took a look, they definitely have gone to a lot of trouble, it is not one of my kits and you will need to fill in the back bumper, there is a big gap between the exhaust pipes.....
They have kept the original grille opening and used the X150 bottom half, I do mine different as in the pic below, my main problem would be the fact they have grafted plastic to metal and to other bumpers, probably quite thick filler which could be prone to cracking
Still might be a bargain for someone though
Wow there are a ton of them on ebay.uk for a song.
High miles typically, but then they're well over 10 years old.
Looks like they got the signal repeaters over there before we did (this is a 1997)...
They'll bottom out at some point if they haven't already. There's nothing to prevent the XK8/XKR from becoming a future classic and it has all the ingredients in place. As much as I admire the design of the E-Type, I find these cars to be considerably more desirable.
PlatinumJag
20
Oct 2, 2020 02:23 PM
John Fox
Sep 19, 2015 07:56 PM
