XK8 1999 indicates lights
Old Sep 28, 2017 | 05:05 PM
TomandCheryl's Avatar
Default XK8 1999 indicates lights
after starting indicater lights coming on and staying on, ABS , Amber light, traction control fail, stability control fail, and passenger airbag light. Is this a loose wire as car seems to be running okay. Only had this car a few days
Old Sep 28, 2017 | 05:26 PM
Welcome to the forum TomandCheryl,
I've moved your question from General Tech Help to XK8/XKR forum. Members here with the same model will be able to help.
Old Sep 28, 2017 | 07:36 PM
RJ237's Avatar
Those are all the symptoms of a weak battery. Have it load tested at a auto parts store, or just charge it for a couple of days and see if the lights go away.
Old Sep 28, 2017 | 11:05 PM
Jandreu's Avatar
Also do a hard reset, take the positive terminal cable off the battery and touch it to the negative terminal for 5 seconds.
You will have to reset the window travel by sitting in the car with the doors closed, run the front windows down and hold the switch until you hear a click, run them up and do the same, I always do it twice.
Old Oct 1, 2017 | 06:10 PM
I took the car to Advance Auto and had the battery checked. The battery checked out fine with a full load. Actually the battery looks like a pretty new one. They scanned the car and it came up P1000. I then did a hard restart by disconnecting the battery. The traction control light and the stability warning light went off. Still have ABS and airbag light on. Need to figure out how to remove passenger airbag cover to check to see if there is an airbag. There is a small crack on the airbag cover
Old Oct 1, 2017 | 07:44 PM
motorcarman's Avatar
You are wasting your time looking for problems that the modules themselves will have info stored as DTCs.
Find someone with the correct compatible code reader for Chassis and Body modules.
bob
Old Oct 2, 2017 | 02:28 AM
Originally Posted by TomandCheryl
..... They scanned the car and it came up P1000. .....There is a small crack on the airbag cover.
P1000: OnBoard monitoring tests not completed since last memory clear
It looks like someone has attempted troubleshooting the issues recently and cleared any DTC's. You would always hope to see P1111 (indicating all OnBoard monitoring tests complete) and I understand this is a requirement in many states to pass emissions testing.
I don't like the sound of any physical damage to the airbag. It could be faulty or even worse, compromised in the event of an accident.
motorhommie
May 19, 2017 10:34 AM
Terry Young
Feb 24, 2017 10:46 AM
skyscuba
Jul 25, 2009 03:21 PM
firstjag
Dec 11, 2007 06:39 PM
miatasportscar
31
Oct 10, 2007 10:06 PM
