XK8 Convertible Top Problem
Old Jun 20, 2015 | 08:41 AM
Gibso's Avatar
Hi
I have read your problem and here is my thought.
The top stopped working at the point where it needs a signal from the right hand ram that it is fully extended.
Remove the back seat, I use this term lightly, and inspect the connections on the bottom of the ram. also follow the leads along the floor about 18inches to a connection plug. This plug can get corroded. This plug is a great place to test the operation of the switch inside the ram.
If the system does not receive the fully extended signal the pins and latch on the header will not close and the rear windows will not come up.
The rams internal switch is quite reliable so I would suspect connections.
Be careful when moving the top by hand as you can damage the frame.
One last comment. The rear windows receive a timed signal to close once the top is fully up. There are no signals sent to the close or open top system from the rear windows.
Good luck Mike
Old Jun 20, 2015 | 09:33 AM
Jandreu's Avatar
Originally Posted by Gibso
Hi
Good luck Mike
Did you happen to notice this is a ten year old thread? Happens to all of us, LOL
Old Jun 20, 2015 | 11:20 PM
Stamford's Avatar
Actually, the thread was never closed, so maybe the OP is still chasing the cause! ;-)
Old May 4, 2025 | 01:34 PM
MaxTorq's Avatar
hello all,
my '05 vert is having this same problem...ok... i probably caused it.
i have had XKRFACE on a lift for too long. i started her up and decided to work the top down and up several times to get the fluid circulated in hopes of changing the factory fluid (i am pretty sure) before it turns acidic. well, half way up, on about the third? cycle it stopped. i disconnected the batt in hopes it would clear...nope. i disconnected the batt and charged it over nite, reconnected and still no... scanner does not show a module to reset for the top... i have it (gently) manually open and into the boot. How can i reset the system ?
HELP !!!
THANK YOU !! in advance for any assistance,
Max & XKRFACE
...i luv this car...
jdzubas
Oct 4, 2015 09:14 AM
msdg137
Sep 16, 2015 06:24 AM
reedmtn
Sep 5, 2015 08:04 AM
jbjb_007
Sep 1, 2015 02:02 PM
Jandreu
Aug 29, 2015 07:31 PM
