XK8 electrical fault
Old Dec 29, 2017 | 12:01 PM
fmertz's Avatar
Originally Posted by steve xk8
The car is stuck in park in my garage and I cant move it as it wont start and seems to be unable to de-select park. I am not over familiar with these cars and at the risk of appearing daft here , is there a way of getting it into N so that I can move it and transport it to have the work done.
I'll say it again, all of this points to the brake switch. The switch informs the module to activate a solenoid to release from Park. If you put your finger in the general area of the shifter, you can feel it. You should be able to hear it in a quiet environment, too.
To force the release, you need to unscrew the plastic plug near the shifter. Once off, you can use something to force the release (screwdriver, key?). It is documented in the owner's manual...
Old Dec 30, 2017 | 04:42 PM
steve xk8's Avatar
Okay .The new starter motor is fitted and the car is purring again.
the voltmeter is now showing 12 volts with the engine running and about 10v with ignition on so its still low but the car starts up every time and runs 100% which is what matters most. I have 13.2 v at the fully charged battery terminals.
Many thanks for all the replies. I apprecate it.
I am now a happy bunny again and so is the owner at my local petrol station. ! !
JimC64
Sep 22, 2025 02:52 PM
Phil Preece
Oct 17, 2016 01:41 AM
97 Xk8 mayhem
Oct 8, 2016 01:27 AM
sjuraud
Aug 28, 2010 02:11 PM
JimC64
Sep 10, 2009 12:44 PM
