XK8 flip key compatibility
Old Apr 15, 2017 | 04:22 PM
Salu498's Avatar
Default XK8 flip key compatibility
If I buy a flip key from EBAY or other source, what is involved in making it campatible with my 2006 XK8?
Old Apr 15, 2017 | 10:47 PM
prettybluefin's Avatar
i just had a new flip key cut for my XKR yesterday. the rib of the key is longer on the XKR key than standard, so they had to use a longer blade.
i believe the ones sold on Ebay have the shorter ribs...ask seller to give measurements so you can make sure it matches the length of your key...
(chrome sided case is XKR key, rubber case is my XType Sport key) Front and side views...
Old Apr 15, 2017 | 11:35 PM
bcprice36's Avatar
PrettyBlueFin, How can I get one of those Plastic flip-key-holders? What do they need from me? Beside Money! Do they need the Car? I assume they will need a key.....at least...
Billy Clyde in Houston
Old Apr 15, 2017 | 11:46 PM
I think they need the car to program the key so it will work...and the original key, which they clone, so you end up with your original and a new flip key...The hardest part is finding a locksmith who will cut your Jaguar key...
I don't know, I just gave them my money, they provided new cut key, flip fob, and programmed for me. $250
Old Apr 16, 2017 | 04:20 PM
bakntyme's Avatar
Check out this old thread if you want to convert your key and remote to a flip-style. I did it to one of my keys a couple of years ago and it has worked fine since.
This method requires no dealer or locksmith cutting of the key blank or reprogramming to the car, since it uses your existing working key and code module.
https://www.jaguarforums.com/forum/x...ictures-93167/
Old Apr 16, 2017 | 04:59 PM
i was trying to work up the courage to try your hack, but the transponder extraction terrified me
Old Apr 16, 2017 | 05:08 PM
bakntyme's Avatar
I can claim no credit for the conversion technique. I was simply one of several owners who used the detailed information and pictures provided by the original poster in that thread, Pomosv. I had two keys, so wasn't too worried about damaging the transponder...but I did the conversion to just one key! A soldering gun worked well to cut the key by melting and expose the transponder for extraction without damage.
