XK8 front camber adjustment
Old Aug 7, 2025 | 06:16 PM
Theo14's Avatar
Default XK8 front camber adjustment
Hi All.
My XK8 has excessive negative camber on the front end (inner tire tread wearing). I measured it at -3 driver side and -2.5 passenger side.
I have done/checked the following:
-checked for signs of wear/play in the lower control arm bushings (as much as I can without taking the control arm out. They look ok and no movement when I check for play with crow bar.
-checked ball joints for obvious deterioration.
-checked ride height (both sides 405mm, which is actually a few mm more than spec)
-newer suspension mounts still look good
-upper suspension bushes were replaced last year
-I thought later models had the eccentric adjustment bolt standard, but mine doesn't have this. Also I understand this will only make a very light adjustment possible.
Don't really want to replace the lower control arm bushes if I don't need to, but am kind of thinking that's the next thing.
Hoping I'm overlooking something and someone has a suggestion on how to fix this.
Thanks!
Old Aug 7, 2025 | 07:49 PM
RJ237's Avatar
Check for toe out. I adjusted mine after finding it was about 1/16" and it's now 1/16" toe in and no tire wear.
Old Aug 7, 2025 | 08:16 PM
cjd777's Avatar
What is measurement from the center of the wheel to the edge of the curve in the fender.
Should be in the Neiborhood of 15.5 inches, that will tell a lot.
Old Aug 8, 2025 | 08:29 AM
Theo14's Avatar
Thanks for the suggestion. I'll check for this.
Old Aug 8, 2025 | 08:32 AM
Theo14's Avatar
Thanks, I did measure that at 405 mm which is 15.9 inches. I read somewhere spec was 15.75. Slightly higher ride height should make camber less negative.
Old Aug 8, 2025 | 05:29 PM
cjd777's Avatar
might have to get out the wrenches and look at that lower A arm.
Old Aug 9, 2025 | 07:23 AM
PKWise's Avatar
Sorry I disagree, Slightly higher ride height will make Camber MORE negative. This is because the upper Wishbone has a shorter Radius than the lower Wishbone and both are mounted near parallel in geometry. Having said that, your ride height is just 4 millimeters too high and I can't see this alone creating the Camber angles you have.
Old Aug 9, 2025 | 08:51 AM
michaelh's Avatar
Aye, any deviation up or down from parallel will reduce camber. Specs allow ± 15mm / 0.59" tolerance on the ride height.
Are the upper control arm bushings still good?
Old Aug 10, 2025 | 09:49 AM
Theo14's Avatar
Yes, upper control arm bushes were done less than a year ago.
toronadomike
Jun 23, 2013 11:16 PM
dneu
Aug 6, 2012 09:49 PM
Skid Mark
Dec 24, 2011 02:30 PM
rabbits2
Aug 21, 2011 01:46 PM
