XK8 Headlight/Headlamp Bulbs - Need Some information
Old Feb 13, 2011 | 01:30 AM
o2manyfish's Avatar
Default XK8 Headlight/Headlamp Bulbs - Need Some information
Hey Guys,
Last night one of my headlights burned out. I went online and did some Googling and came up with a D2S bulb, but running around today I couldn't find one (for $126 bucks a bulb).
Then I removed the bulb and its hard to tell if its blown (hoping its a bulb not a ballast issue). But while shopping tonight from the photos I have seen I am looking for an D1S bulb which has a square metal base on the bottom of it.
So these bulbs are available from 40/pr to 244/pr to 466 for PIAA on Google.
So my question is... Which bulbs do I want? Anyone have experience with the different manufacturers and different colors and a vendor to recommend for this.
From what I have read, I think I want to replace both sides so that the headlamp colors match.
THoughts ????
Dave B
Old Mar 5, 2011 | 06:38 PM
jagxk8vert's Avatar
I'm in the same situation. I want to put in Xenon HID purple 12000 headlight bulbs but I think it requires a conversion kit. I believe they're halogen lights in there now. Do you know??
Jim
Old Mar 5, 2011 | 07:21 PM
Reverend Sam's Avatar
Jim
NNNNOOOOOOOOO!!!!!!!!!!!!!!
Old Mar 7, 2011 | 05:34 PM
Beav's Avatar
I've got 6k's in my Lincoln and with conventional reflectors the color is perfect. However, 6k's with the Jag's projectors are too blue. The 4300s would be a better choice to see by. Assuming you're in search for some funk with the 12k's I'd suggest dropping down a few pegs because, considering the low height of the lamps to begin with, anything much over 6k will drastically inhibit your vision. And if you're considering HIDs for the high beams don't forget how the lag time for warm-up will affect turning them on.
Old Mar 7, 2011 | 10:12 PM
H20boy's Avatar
02fish, ebay search for 'D1S OSRAM' results in plenty of (OEM) bulbs, and if you replace with a new one, I'd just do both at once to keep the output the same, or you could buy one of the used OSRAM bulbs, and hope they're pretty close...that'd be the cheapest route - $20. If it were me, I'd do the $130 for the pair.
Old Mar 8, 2011 | 12:21 PM
mutaG3N SRT's Avatar
Lightbulb
I have installed 4300k HIDs on my '99 XK8 replacing the halogens for $ 60.00 with a relay cable included. Better off than paying $ 126.00 for one bulb and you get to customize the set up as you like.
Old Mar 8, 2011 | 01:18 PM
H20boy's Avatar
hey muta, kudos to you for at least going with the 4300k HIDs, and if you have to get new ballasts and connectors, aftermarket kit is the way to go! Did you see we have a poll in the Exterior section of teh forum, just for this very topic - color of HIDs?
In 02s situation, he already has the system, his ignitor and bulb is at fault...and if he went aftermarket, he'd have to replace more than just a single part. That's probably why he's looking for OEM replacement.
Old Mar 9, 2011 | 07:42 PM
Yeah! I was just looking at it. They should be white but the lens makes 'em light sky blue, looks good. When you hook up highs and lows together it's a pleasure at nite!
Old Mar 10, 2011 | 07:54 AM
jagxk8vert's Avatar
H2o boy,
So if I want to put in new HID lights I'll need a conversion kit, correct?
JN
Old Mar 10, 2011 | 09:46 AM
H20boy's Avatar
That is correct JN. Get a quality kit if you do.
Old Mar 11, 2011 | 06:41 AM
jagxk8vert's Avatar
h20boy, what would you recommend for a kit? I want to put in blue (ish) lights. I have 12000k in my ls430 and love them. What would you recommend for the Jag?
Old Mar 11, 2011 | 11:18 AM
H20boy's Avatar
This is a thread from a previous forum sponsor, that probably still sells these kits. Lots of good reviews you can read about in there.
By all that is good and holy in the world, please do not do more than 6000k. Our poll shows that this is the most 'attractive yet safe' color spectrum.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
ericjansen
Dec 19, 2021 12:20 AM
afterburner1
Dec 16, 2015 12:12 AM
avern1
Sep 8, 2015 06:25 PM
