XK8 Seat switch removal
Old Mar 9, 2026 | 08:14 PM
Yann's Avatar
Question XK8 Seat switch removal
Hello,
I need to remove the seat switch (LJB6035AA) of my 1997 XK8 ... without breaking anything. There is no screw on the seat switch and the connector is merely accessible on the other side so I don't know how to disconnect the connector.
Any step by step recommendation?
Thank you!
Yann
Old Mar 10, 2026 | 09:52 AM
Jag_Willi's Avatar
Hello,
Here is a picture from behind. You can see the nose there. Press gently against the nose and lever it out. If the nose breaks, you'll be annoyed because the part will always come loose.
Schalter
Best regards, Willi
Old Mar 12, 2026 | 09:34 AM
Yann's Avatar
Hello Willi,
thank you for your reply and for the picture, but I'm not clear how I can press on the nose as it is inside the seat. Shouldn't I try to pull on the other side from the nose or push the connector?
Thanks.
Best regards.
Yann
Old Mar 12, 2026 | 10:46 AM
Jag_Willi's Avatar
Hello,
The nose is just stuck.
Kneel in front of the seat, push a little harder from right to left, or carefully pry it open.
Best regards, Willi
Old Mar 12, 2026 | 11:09 AM
michaelh's Avatar
This thread from Colquan1066 has some pictures of the switchpack disassembled that may help:
https://www.jaguarforums.com/forum/x...4/#post1840629
pcolapacker
Jan 3, 2025 08:28 PM
Glenn Barickman
Jul 19, 2015 05:15 PM
yosy
Mar 18, 2014 08:37 PM
jjane1
Aug 7, 2012 07:36 PM
dpm
Dec 7, 2011 01:02 PM
