XK8 Shifter Cable replacement and more!
Old Jan 15, 2026 | 08:11 PM
erjent's Avatar
Default XK8 Shifter Cable replacement and more!
Hi All,
This morning as I was pulling into the parking spot where I pick up my work vehicle, I said to myself "This Cat is running Really Nice". When I went to put it in Park I had a Normal click thru Neutral, then a free shifter. I snapped the shift cable at the connector nut.
How much of a job is it to change the cable, and will I need to make very much adjustment to it? It looks pretty straight forward. I also found three broken pieces of plastic in the shifter housing. They appear to be part of the disk (Maybe 1/5 of the plate) that rotates when going to the J-Gate, but that's all there was. No full plate. I thought there are micro switches telling the ECU what gear you are in when using the J-Gate, but I don't see any on the left side of the shifter box. Also, what is the micro switch at the front of the shifter for? I doesn't seem to be contacted by anything that I can see.
Much thanks,
erjent
Old Jan 15, 2026 | 08:30 PM
erjent's Avatar
As soon as I posted this I found a video on Youtube about the shifter. The man making the video has a XKR and his shifter did not have the round plate installed. Some one donated you to him to fix his issue. I'm guessing that these break easily. Is there a replacement available?
I found a sticker LJA 6195 BF attached to one of the broken pieces.
Old Jan 16, 2026 | 03:48 AM
dibbit's Avatar
There are three different types of gearboxes on these cars, and I would guess three different types of gear shifter mechanisms. If you tell us which one you've got it would help with the answers.
Old Jan 16, 2026 | 08:56 AM
motorcarman's Avatar
MAKE, MODEL, YEAR will help with your questions!
Old Jan 17, 2026 | 10:08 AM
erjent's Avatar
Sorry,
Jaguar 2000 XK8 Convertible
Old Jan 17, 2026 | 12:27 PM
The D4 cam plate was NSS (NOT SOLD or SERVICED SEPARATELY) from Jaguar when I was at the dealer.
Maybe someone has them now?
Get a used one or maybe have it 'printed'?
The CAM operates the switch when the selector lever is move from DRIVE to 4th.
Old Jan 17, 2026 | 10:55 PM
erjent's Avatar
Yeah, I would love to get one printed. Just need the file.
00XK8
Jun 10, 2023 03:24 PM
TBanks98
Sep 1, 2021 08:04 PM
R-Rocks
XJ40 ( XJ81 )
Jul 4, 2016 04:31 PM
tony1963
Jul 28, 2012 03:26 PM
guenzak
Mar 23, 2008 09:23 AM
