XK8 timing Chain and Tensioners
Old Mar 22, 2014 | 06:26 AM
mctb's Avatar
Default XK8 timing Chain and Tensioners
Having just acquired my 1997 XK8 convertible its now time to get it ready for the summer, so i looking to change the Tensioners, Timing Chain and maybe VVT's and water pump WHY i have a rattle at the front of the engine have changed the VVT solenoids but still the same. I have the workshop manual but the process isnt that easy to follow does any know anywhere on the net where there is a step by step guide
Old Mar 22, 2014 | 07:52 AM
Welcome to the forum mctb, I've moved your post to the correct section.
Don't forget to post an intro in the new members section.
For help with the tensioners check out the "How To" section for some excellent links https://www.jaguarforums.com/forum/x...ts-data-29800/
Old Mar 22, 2014 | 08:45 AM
mike66's Avatar
Welcome
There's a ton of material here on the tensior job, including part #'s, where to buy, and exact play-by-play steps. Just holler if you need some help. Most of us with 4.0's have been through it.
Old Mar 22, 2014 | 12:25 PM
RJ237's Avatar
I don't think the VVT solenoids are likely to be a problem. They do click when operating, but not very loud.
Old Mar 22, 2014 | 12:48 PM
Fulton's Avatar
Welcome MCTB, I am just taking a break, doing the secondary tensioners today. so far so good, thankfully I didn't remove the spark plugs yet as I dropped a 7mm socket down the hole. geeeez that was close! the complete instruction are in the DIY repair and maintenance section under XK8/XKR or just use the search function. it's all there
Old Mar 22, 2014 | 02:26 PM
ArtyH's Avatar
Smile
Hi and welcome to the forum and congrats on the purchase of the big cat!!!
I am doing the same job as you and if you check " The refurb begins " post you will get a good idea of how far I have got on with the job. If you look in the stickies there is an excellent review of how to do the job by EZdriver https://www.jaguarforums.com/forum/x...ics-how-52653/ .
If you are unsure of anything or want a bit of advice on how I am doing it just post in the refurb thread and I will try and help.
I would start with the drivers side as I found it easiest.
Best of luck,
Arty
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
Sep 29, 2025 10:51 PM
kelliott
May 31, 2022 05:26 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
David Thompson
Sep 3, 2015 07:48 PM
