XKR 2001 Conv Rear Bumper
Old Jul 12, 2010 | 08:41 AM
stevemoore's Avatar
Default XKR 2001 Conv Rear Bumper
Can somebody please tell me, in simple terms, how to remove the rear bumber from my XKR. Thanks
Old Jul 12, 2010 | 10:24 AM
H20boy's Avatar
I did mine recently, its not that difficult. If you're taking it all the way off, you'll have to disconnect all of the little backup sensors. (if yours has them)
(1) Just behind the rear wheels in the fenderwell, you need to remove those 1/2 size plastic pieces. Screw caps only.
(2) on the inside of the bumper cover, behind the rear wheels, there is a slotted guide that the bumper goes in. It is secured with one bolt, just loosen so the cover can slide easily back and forward. Mine was really gummed up and stuck, so you may have to loosen with some wd-40 or soapy water.
(3) there are two large bolts that thread from underneath the bumper, into the impact 'shocks', can't remember the technical term, sorry. Just unscrew those all the way.
(4) slide the rear bumper directly away from the car. (get someone to help, it is awkward to control once it releases from the side skirt guides.)
Easy sneezy.
Old Jul 13, 2010 | 02:58 AM
stevemoore's Avatar
Default Thanks
Brilliant, thanks for the advice, a job for this weekend!
Old Jul 13, 2010 | 08:56 AM
H20boy's Avatar
I was able to remove my bumper, set it on a stack of milk crates behind the car, make my 'repairs' on the car, without removing any lights or backup sensors in the process. Good luck.
toronadomike
Jan 22, 2026 10:13 PM
Skeeter
Sep 17, 2015 08:15 PM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
obwoodie
Sep 3, 2015 07:45 PM
colorancher
Sep 3, 2015 02:29 PM
