XKR 2001 starting problem
Old Feb 28, 2014 | 04:41 PM
jim graham4300's Avatar
Default XKR 2001 starting problem
Hello,
Maybe someone has some thoughts on my issue.
My 2001 XKR has around 44,000 miles on the clock. Drove it earlier today to run a few errands. My first stop was 15 miles from home. Returned to the car after 5 minutes and it would not start. Fully charged battery/full tank of gas. It emitted very weak sounds of combustion and then stalled. Would not start.
No smell of gas, so I am guessing that it might be a fuel delivery issue??
This happened once before and I let the car sit overnight. It stated ok the following day.
Any thoughts or advice would be appreciated.
Thank you,
Jim
Old Feb 28, 2014 | 05:29 PM
Jim,
I've moved your question from XK / XKR (2006 - Onwards) to XK8/XKR (1996-2006) forum.
Old Feb 28, 2014 | 06:13 PM
test point's Avatar
Your estimate that it is a fuel delivery issue is probably correct.
Next step is testing the fuel pressure at the Schrader valve on the fuel rail. The R's with their 2 pump are famous for one failing and the car continues to run until the other one stutters.
Old Feb 28, 2014 | 06:17 PM
WhiteXKR's Avatar
Next time is does not start remove fuel pump relay number 1 and try to start several times. If it starts after 5 or 6 tries, it is now running on fuel pump number 2 the problem is likely fuel pump number 1.
See https://www.jaguarforums.com/forum/x...el-pump-85882/ for more details.
fast40driver
Apr 19, 2024 07:24 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
1964Daimler
Sep 2, 2015 11:41 PM
tony bosco
Sep 1, 2015 02:06 PM
dpappyp
Aug 27, 2015 06:31 AM
