Xkr 2001 water punp. Argentina
Old Mar 15, 2013 | 06:19 AM
RJ237's Avatar
It should be right to the bottom of the neck.
Old Mar 15, 2013 | 07:26 AM
Dennis07's Avatar
Originally Posted by tanngo
sorry sorry -
Level when cold. An inch below full . ok ?
Tanngo,
En mi opinión, está bien allí si no cambia día a día.
(I think I just said that the level is OK there if it stays the same day to day. It is also possible I gave Tanngo a recipe for lemonade.)
Old Mar 15, 2013 | 08:49 AM
tanngo's Avatar
ok thanks, always kept full 70 percent of total.
Old Mar 24, 2013 | 01:33 PM
giandanielxk8's Avatar
Dennis, you didn't give him a recipe for lemonade. No, you told him to go scr--- eh, actually, you were spot on, just missed on the grammar.
Norris, the guy doesn't know english, and I did give an english translation. Read my posts again.
tanngo, el nivel de refrigerante tuyo esta normal. Como dijo dennis, después de que no baje no hay problema.
Para comparar, he aquí la foto prometida, esta un poco más lleno, pero eso no te ha de preocupar. Utilizo el refrigerante verde en vez del naranja porqué el naranja es casi imposible de conseguir donde vivo. Solo recuerda no mezclarlos porqué eso puede causar daños al sistema.
Old Mar 24, 2013 | 02:07 PM
I understand that and appreciate your help, I've read all your posts.
Did you forget this one?
Old Mar 24, 2013 | 03:44 PM
I wanted to see if it would irk you.
Old Mar 24, 2013 | 10:08 PM
tanngo's Avatar
Thumbs up
gracias giandanielxk8 . muy amable , linda foto . nunca intente llenarlo todo , pense que necesitaba camara de aire para expansion . gracias por tu tiempo -
Old Mar 25, 2013 | 07:09 AM
  #28
Dennis07's Avatar
Tanngo says thanks for the helpful photo, and that he never had in mind filling it all the way, thinking he should leave some air in there as room for expansion.
(Or something like that)
Old Mar 25, 2013 | 07:33 AM
Perhaps he enjoyed the lemonade?
Old Mar 25, 2013 | 07:39 AM
  #30
Dennis07's Avatar
I hope so. Family recipe.
What little spanish I retain is from many, many years ago, crammed into my head by a dedicated nun named Sister Mary Europenasia (or similar).
Old Mar 25, 2013 | 04:11 PM
  #31
No hay problema. En realidad no hace falta dejar espacio para expansión. Si esta bien sellado el sistema y no tiene ranuras ni grietas, no debe existir algún gas que cause expansión.
toronadomike
Jan 22, 2026 10:13 PM
mikimogo
Sep 22, 2015 08:09 PM
skadmiri1
Sep 9, 2015 11:27 AM
Saturbo
Sep 8, 2015 07:35 PM
Kmw
Sep 8, 2015 04:52 PM
