Xkr 4.2 2ndry timing chain tensioner
Old Oct 25, 2021 | 04:57 AM
Berks4x4's Avatar
Default Xkr 4.2 2ndry timing chain tensioner
Could you guys give me your opinion on my slack tensioner - should it be sitting back from the chain- does it spring up when the engine is running or is the spring tired?
There is a 5mm gap
between the pad and chain. The tensioner sits back in its lowest position - does the tensioner have a spring in it?
steve.
Old Oct 25, 2021 | 05:25 AM
Steve,
You can't ATTACH a video to a forum post but you can LINK to one hosted on YouTube etc.
Old Oct 25, 2021 | 01:11 PM
xalty's Avatar
yes it has a spring
if both pads are there it is impossible for to jump time. one side is fixed the other moves
Old Oct 25, 2021 | 01:44 PM
Berks4x4's Avatar
Default Xkr 2ndry timing chain tensioner
do you think the spring could be broken- and would I have to strip down the primary chain and cam shaft etc to change the 2ndry tensioner?!
Originally Posted by xalty
yes it has a spring
434MHz
Sep 9, 2021 01:05 PM
tedwone
Jun 11, 2017 02:43 PM
watto700
XJ XJ12 ( X305 )
May 22, 2015 09:02 PM
mitsurugi
Dec 17, 2014 03:04 AM
linconlsv8
28
Feb 20, 2012 12:37 PM
