XKR alarm problem
Old Nov 13, 2012 | 03:15 AM
Neilpms's Avatar
Default XKR alarm problem
have a 1999 xkr soft top
When I set the alarm the internal door handles keep going in and out and the alarm sounds
The passenger side door does not lock itself but the drivers side does
Is there an easy way of resetting this?
regards
Neil
Old Nov 13, 2012 | 12:39 PM
cohibarandy's Avatar
You may want to check your battery. These types of problems sometimes occur with a weak battery. Always the first thing to check.
Old Dec 28, 2012 | 08:35 AM
Neilpms's Avatar
Default alarm lock out
HELP PLEASE
my XKR has decided to lock me out completely, not even the key will work, it just keeps making a small beep whenver i press any of the fob buttons or use the key
i used the key to access the boot and disconnected the battery hoping that it may reset but unfortunately i am still locked out
any ideas please
regards
Neil
Old Dec 28, 2012 | 08:39 AM
WhiteXKR's Avatar
Have you had your battery tested yet? Definitely step #1. It also sounds like a microswitch inside your door latch might be a problem...but the battery should be attended to first.
Old Dec 28, 2012 | 08:58 AM
Neilpms's Avatar
the battery is good, garage on its way, will see what they have to say then get back to you
Old Dec 28, 2012 | 10:21 AM
Neilpms's Avatar
Roadside assitance just left, he spoke to Jaguar and between them they managed to open the car doors, they tell me it is a small micro switch / auto type flap that returns to thwe closed position once the ignition key is taken out, he lubricated the ignition chamber and all seems ok
a new one on me but happy to be up and runnig again so quickly
toronadomike
Jan 22, 2026 10:13 PM
Beardy
Sep 18, 2015 10:00 AM
mcdutch
Sep 4, 2015 03:38 AM
philwarner
Sep 3, 2015 10:14 PM
obwoodie
Sep 3, 2015 07:45 PM
