XKR Convertible Top Latch
Old Aug 20, 2013 | 12:00 PM
perrypower1's Avatar
Default XKR Convertible Top Latch
Hi,
I am having a problem with my 2001 XKR (148,000 miles).
With all windows up I press the top down button.
Front windows drop a quarter of a inch (or something like that, same as when I open the doors.)
I get the warning chime.
The rear quarter windows go down fully.
The top retracts fully, but the pump keep running and the latch does not retract. Makes no difference if I try to press the top down further manually.
If I press on the latch it does go down about an inch, won't go any further, and can't be retracted manually. It will not budge.
After one minute:
The front windows go back up a quarter of an inch and I get the top not latched warning.
The latch 'relaxes' and I can easily retract it manually. The top latched warning goes out and if I press the top down button the pump no longer runs (as expected.)
It seems for some reason it is not starting the top fully down cycle on its own (retracting latch, stopping pumping action, raising front windows.)
The fluid level is correct.
Where should I be looking for the fault? Is it one of the modules on top of the pump? What gives the signal for the top fully down cycle to start.
Top raises and closes and latches fine. There is no binding in the latch and it is properly lubricated, thanks,
Perry
Old Aug 20, 2013 | 12:20 PM
oyster's Avatar
Hi.
Sounds like some kind of electrical gremlin. The easy thing, make a hard reset and be sure battery is fully charged.
File Type: pdf
Old Aug 20, 2013 | 12:52 PM
Thanks you very much for info oyster. I'll give it a try and let you know the results,
regards,
Perry
Old Aug 20, 2013 | 01:06 PM
WhiteXKR's Avatar
Also check the pump fluid level...it could be low. It should be between the two embossed marks on the translucent tank. It is located over the CD player in the boot. If it is low, there may be a leak in the system.
Old Aug 20, 2013 | 03:18 PM
Dennis07's Avatar
I have a strong suspicion about the "Convertible Top Down" switch, which is located on the right hand side (I think) ram, and which closes when the top is fully lowered. It seems the switch may not be closing as it should.
Until this switch closes, the solenoid which controls fluid flow to the latch is set to permit flow in the "open latch" direction ... the opposite of what's needed here ... so even though the pump is running in the correct direction to close the latch, it can't. For the same reason, you can't close it manually either.
See the "Convertible Top Opening Sequence" in the attached.
From fiddling around with this system, I know there are time-outs built in, but the documentation we have doesn't tell us about those. I think a time-out has occurred when the latch "frees up", letting you close it manually. (The latch solenoid has reverted to the "off" state, which permits flow in the direction needed to close the latch.)
Old Aug 21, 2013 | 06:56 AM
Thanks oyster and everyone else for your comments and guidance. The problem ended up being a broken wire from the 'top down' micro switch.
The wiring is located under the rear seat cushion. There is a three wire block. The centre wire had broken away. Repairing this connection solved the problem.
Thanks,
Perry
99xk8guy
Sep 29, 2025 10:51 PM
FrickenJag
Jun 16, 2025 02:15 PM
FeralJag
Jan 11, 2016 05:07 PM
Skeeter
Sep 17, 2015 08:15 PM
obwoodie
Sep 3, 2015 07:45 PM
