XKR Half Shaft Removal
Old Aug 28, 2016 | 09:03 AM
LesF's Avatar
Default XKR Half Shaft Removal
I have a 1999 XKR with a clunk from the rear. Fairly certain half shaft UJ at wheel end has failed. How easy is it to remove half shafts and are any special tools required?
Old Aug 28, 2016 | 11:26 AM
RaceDiagnostics's Avatar
I found that the nuts on the inboard side were very tight and tricky to get to due to the angles. I used a bit of heat to release them. They are a specialised crimp nut.
They are also the only imperial size nut on the car, but I cant remember the exact size right now.
Old Aug 28, 2016 | 07:32 PM
motorcarman's Avatar
The nuts are 11/16"
bob
Old Aug 29, 2016 | 09:45 PM
Ungn's Avatar
Thanks, Bob.
I noticed some other nuts on my car seemed to work best with 11/16". I thought it was just me.
Old Apr 8, 2021 | 11:42 AM
AFTERSHOCK's Avatar
hello
are we talking about the 4 nuts that attach the half shaft to the differential? mine is missing one and i have been trying to figure out the diameter and thread pitch.
so far i found a 7/16-20 lock nut at the store but I'm not totally sure if its right, i need to found out for sure before i stare torqueing it down. I've cleaned it with a wire brush the best i could but im having a hard time starting the nut, due to angle and corrosion.
Segfault
Jun 13, 2019 05:44 PM
iownme
Feb 24, 2019 05:20 PM
AZjag1999
Jun 29, 2018 08:41 PM
andrew lowe
Nov 26, 2014 05:49 PM
magmedia
Jun 24, 2013 06:05 PM
