XKR Hood Vents - painted on bald cars?
Old Oct 17, 2016 | 12:08 AM
2005 XKR's Avatar
Default XKR Hood Vents - painted on black cars?
The topic says it all really. Are the hood scoops on XKRs painted on the black cars like they are on other models? My 2005 is black and the hood scoops, while black, are not painted. Over time thay stand out probably more than they should because of the difference in colors. A little wax helps for a while.
Anyway, is this how the car came from the factory, or was it the result of a precious repair?
Thank you
Old Oct 17, 2016 | 01:34 AM
baxtor's Avatar
Thank you
Mine is 2000 model and black l am sure they are painted but short of scraping away at them can't be 100%
Old Oct 17, 2016 | 02:32 AM
bladerunner919's Avatar
I can't imagine that they painted every colour expect the black ones.
Old Oct 17, 2016 | 04:56 AM
jamdmyers's Avatar
My 02 Air ducts are painted same as body Anthracite metallic black. Might be they replaced them at some point on your?
Old Oct 17, 2016 | 08:27 AM
ccfulton's Avatar
They should be painted.
When I got my car the paint on the vents was cooked pretty badly, either from engine heat or the sun or maybe both. They were dull like you describe and while wax would help, it didn't last long.
The fix it to repaint them or do something like a hydrodip.
Old Oct 17, 2016 | 04:24 PM
theweeb's Avatar
Thank you
Mine are the same way, black, almost powder coated, but not glossy like the rest of the hood. I am considering the chrome mesh ones..
Old Oct 18, 2016 | 11:37 AM
2005 XKR's Avatar
This photo really shows what I'm talking about. Powder coated is an excellent description.
Old Oct 18, 2016 | 12:39 PM
theweeb's Avatar
Same here...
Old Oct 18, 2016 | 12:45 PM
2005 XKR's Avatar
So it seems it may be an issue related to the later cars, or maybe even just the 2005s. Does anyone have a black 2006 xkr that can comment on how his looks? What about an 04?
Old Oct 18, 2016 | 01:24 PM
fmertz's Avatar
OT: Like your flooring. Any pointer for me to look it up? Thanks.
Old Oct 18, 2016 | 01:39 PM
2005 XKR's Avatar
I had it done by these guys. It took a weekend. Very easy and we are extremely happy with it - it's virtually bullet proof. It's supposedly a much better finish than you can get DIY as they grind the floor with a diamond grinder and then use some serious chemicals. I think it has a 20 year warranty?
Garage Flooring Systems Garage Floor Coating Solutions
Old Oct 18, 2016 | 01:55 PM
motorcarman's Avatar
Painted metal and painted plastic probably react differently to UV exposure.
bob
Old Oct 18, 2016 | 07:54 PM
ccfulton's Avatar
My 03 looked the same way before I painted them. Don't think it's year related.
Old Nov 1, 2016 | 01:11 AM
2005 XKR's Avatar
So I wanted to follow up and share that I was able to greatly improve the look of the vents with Griot's trim dressing. I just applied with a microfiber rag. The pic shows the difference that one coat made... two more has it blending in almost perfectly. I don't know how long this will last, but I will update. I'm sure back to black or similar products from other companies would do the same thing, I'm just partial to Griot's products myself.
Old Nov 1, 2016 | 08:23 AM
guzzi svt's Avatar
My Red XKR has the same problem but not as pronounced as the black. I'll try your idea with some of the new coating systems out there.
Old Nov 3, 2016 | 02:14 PM
Sparky77's Avatar
Hi,
I've got a 2003 XKR, per the colour code is Midnight Black. I've noticed in some light, usually when dark and under artificial light (not as pronounced in daylight) the vents are slightly different to the bonnet. However mine appear to be more of a different shade (a dark grey perhaps) with a finish to them (with metallic flecks and such) rather than having simply faded and showing any signs of damage. Also noticed the wing mirror covers and the boot spoiler the same. So perhaps in my case was a finishing choice taken by the original owner. Can't see how they'd all have gone the same way, with no sign of damage to them.
Perhaps that's how some cars are. Will try and get some close up pics.
Unless the whole car has been resprayed and they weren't touched, which would be an odd decision to take. If spraying all of it who'd skimp on a couple of small plastic trims?
Stuart
Old Nov 3, 2016 | 08:44 PM
hm1's Avatar
hm1
Why put dressing on paint?? It's better to just pop them off and get them repainted. It will look 100% better!
Don't be lazy, do it the right way
LesF
Apr 8, 2021 11:42 AM
Scott S
Dec 23, 2016 07:02 PM
omgimali
Aug 31, 2016 09:20 PM
jwooky
Aug 31, 2016 03:33 PM
XKRNorway
Aug 25, 2016 02:53 AM
