XKR Quirks
Old Jun 3, 2024 | 06:53 AM
rwinterslaw's Avatar
Default XKR Quirks
Mates:
Just purchased a 2006 XKR convertible with 16K miles. Looks great, runs great.
Query, by 2006, had Jaguar worked out the issues with the timing chain tensioners and the convertible top "green shower" feature?
Also, yesterday during a 50 mile cruise, the low coolant warning light came on and off a couple of times, without any temperature gauge deviation from normal range. Any thoughts on this issue?
Thanks in advance for your collective assistance.!
Old Jun 3, 2024 | 07:27 AM
zray's Avatar
Have you taken the cap off of the expansion tank to see if the fluid actually low, or if the sensor is sticking ?
Z
Old Jun 3, 2024 | 07:38 AM
JimmyL's Avatar
Don't trust the temp gauge. Don't let it overheat. Don't mix orange and green coolant. The green shower was an issue on the later model cars too. I had my hydraulics all replaced by Marvin. Just my .02.
Old Jun 10, 2024 | 07:26 AM
Shundi's Avatar
Originally Posted by rwinterslaw
Mates:
Congratulations! I had the same coolant issue - ended up replacing the expansion tank as it was super brittle (sits right next to the very warm engine) and the new tank includes a new sensor. Be careful when replacing the hose clips as they can weaken and cause a leak under pressure (ask me how I know) which will be very confusing as you’ll see the “low coolant” alert again. These cars also seem sensitive to the coolant mix so don’t just top up with distilled water. Good luck and enjoy!
Sacho
May 30, 2024 09:33 PM
funracer
Jul 26, 2019 09:30 AM
jagxkrtoofast
Feb 24, 2012 07:45 PM
