XKR Steering Problemos
Old Apr 5, 2010 | 09:17 PM
H20boy's Avatar
i'm fresh out of humor tonight...but relating to your problem, my car felt like it was 'wandering' when my lower control arm bushing was gone. New ones, and a fresh alignment (could aline be your problem) and the car is straight again.
If it were me, i'd find a new alignment shop that will 'load' the suspension so the toe is correctly set. Thats a biggie that often gets pooched!
Old Apr 5, 2010 | 11:57 PM
DpezXK8's Avatar
Sounds about right, I'd check the control arm bushings. Make sure to check the uppers as those make a big difference in steering quality.
Old Apr 6, 2010 | 07:56 AM
Brutal's Avatar
In additions to forementioned check the upper strut mounts, the nuts should be exactly centered with no degradation of the foam(for lack of better word) around the nut. This is a common issue with time and drops ride height and creates too much negative camber. Other than that a proper alignment is the direction to head after that
Old Apr 6, 2010 | 06:53 PM
H20boy's Avatar
While he's in there, check those upper mounts... really helps to have 'non saggin' ones to bring the camber back into spec. Just saying, while he's got it apart. Those things simply age and give up.
Old Apr 6, 2010 | 09:42 PM
BurgXK8's Avatar
Originally Posted by fretbored1
If you don't have an answer, tell us a funny joke.
Q: Why don't the British make computers?
A: Because they couldn't figure out how to make them leak oil.
(....Thank you very much folks, I'll be here all week!)
Old Apr 6, 2010 | 09:48 PM
BurgXK8's Avatar
I replaced the sway bar bushings. The ball joints are tight. I'm down to the rack.
Sway bar bushings would have little if any impact here; ball joints might help a bit, but I'm with the other Dpez - how do your control arm bushings look? How many miles on the car? I suspect that if the rubber bushings are blown (visible cracked or egged-out holes instead of a tight fit), that's like a torn rotator cuff in terms of steering stability. It's also a very labor intensive job. Good luck.
Ozzy_UK
45
Feb 19, 2019 02:05 PM
Ozzy_UK
General Tech Help
Jan 14, 2016 02:52 PM
Bcrary3
Sep 26, 2015 10:36 AM
RobertTheBloke
Sep 24, 2015 11:48 AM
WhiteTardis
Sep 17, 2015 09:29 AM
