XKR X100 2001 72k. Battery won't hold charge
Old Jun 26, 2018 | 02:24 PM
stevema7162's Avatar
Default XKR X100 2001 72k. Battery won't hold charge
Following a longer than usual spell of sitting on the driveway not being used, I charged the battery and began using the car, but within a day, the battery was flat again, and would not turn over. It's fitted with a sat nav, so has no volt meter, but I don't know if it's a battery fault, a power drainage issue, or a charging issue. I have charge light on. Any pointers welcome.
Old Jun 26, 2018 | 03:03 PM
JagV8's Avatar
Basic idea is to start with a known good battery and charge it. Then use a meter to find any drain. Can require a lot of time and logical thinking.
Also, to check whether alternator is charging.
There are threads about this all over the site (& net) you may as well read.
Old Jun 26, 2018 | 08:51 PM
Ophitoxaemia's Avatar
That sounds like the battery might be bad. Also sometimes it's hard to charge a very dead battery.
I tracked down a parasitic drain on my car. Not too bad but there are a lot of fuses!
Old Jun 26, 2018 | 10:51 PM
brobin's Avatar
There are 3 things you want to look at first. 1. Check the battery with a load tester; 2. Check the output of the alternator; and 3. Check the operation of the voltage regulator. If it's not one of those 3 then look for parasitic drain sources. I once had a brand new car die on the way home from the dealership due to a bad voltage regulator. The VR is the gateway between the alternator and battery. It can prevent a good alternator from charging a good battery.
Old Jun 27, 2018 | 12:35 AM
Redline's Avatar
There's a 4th thing to check; make sure the battery connections are tight. If one or both connections are the tiniest bit loose, the battery will not charge properly (speaking from experience...).
Old Jun 27, 2018 | 08:06 AM
brobin's Avatar
Good point! I'd actually rate that as #1!
Poet
Apr 11, 2022 06:51 PM
Jagst
Jan 5, 2017 04:57 AM
Mark JC
Nov 7, 2016 03:16 PM
fwinny
Oct 21, 2016 09:01 AM
ben556473
Apr 12, 2008 06:27 AM
