your recommendations
Old Jul 24, 2011 | 06:09 PM
mapatton's Avatar
Default your recommendations
Fairly new here. Purchased a 2003 XK8 a number of months ago. Sorry to say, already had the green drip (at least it wasn't a shower), so needing to make that repair. Now a metallic rattle in the drivers door. Some searching here suggests a complex metal plate? in the door that is fastened with one bolt. Also within the next year, thinking I am wanting to address suspension bushings.
Just ordered the JTIS cd. So here is my question:
What tools other than the ordinary would you recommend that I acquire as we are looking to keep this car for sometime and repairs will largely be DIY.
IE: I already know I will be removing door/interior panels. Any tools that you found were necessary, or much better to get the job done?
Many thanks!
Mark
Old Jul 24, 2011 | 08:17 PM
porkenstein's Avatar
There is a good video on removing the door panels on this forum. https://www.jaguarforums.com/forum/x...its-faq-37325/ The video is towards the bottom of the posts. It looks real easy.
Old Jul 24, 2011 | 08:21 PM
test point's Avatar
Most of the work on my Jaguar is done with a $10 set of 1/4" ACE hardware sockets. I found a wonderful door panel removal tool at Harbor Freight that I wish I had had in the tool box for the past 40 years. Panel Clip Pliers
Do a search and you will find a 'how to' on door panel removal.
Jaguar has some special tools but unless you doing some serious repair a simple set of sockets will do for most things.
JTIS is available for download from this forum for free.
Old Jul 24, 2011 | 08:26 PM
WhiteXKR's Avatar
+1 Those panel clp pliers will pop your interior A-pillar trim right off easily in addition to the door panels. You will need to do this for the hose repair.
Also a set of torx sockets will be handy.
Old Jul 24, 2011 | 10:53 PM
lovemycar1's Avatar
I also think the cable operated hose clamp remover tool is a valuable addition to your tool box. Both snap on and sears have it. You can order the Sears one on line. Makes underhood work much easier.
Old Jul 24, 2011 | 11:26 PM
I had never heard tool. I just looked at Sears to see what it is. That's a definite addition to my toolbox. Thanks.
Old Jul 25, 2011 | 02:15 PM
mapatton's Avatar
Many thanks everyone.
here is another Q:
The Jag is a 2003 XK8 with just shy of 60K. I have no idea what oil has been used in the past. Is it safe to go synthetic?
Old Jul 25, 2011 | 02:26 PM
test point's Avatar
Of course. I never believed the old 'synthetic oil causes leaks' opinion. If the car was serviced at a Jaguar dealer they just put in good quality dino oil but I have always run full synthetic with outstanding results. Another car in the garage with 145k miles uses about 1/4 qt of oil in a 10k mile change interval.
Old Jul 27, 2011 | 01:32 PM
mapatton's Avatar
Curious, I am planning to replace the front top shock mounts. While I am doing this it seems I should go ahead and do bottom bushing.
I haven't checked the other front supension items, but with digging into the front end for that top mount, what else should I just go ahead and do. IE: Upper support bushings, etc.
Car steers fine and smooth with no loseness but has a rickety feel on bumps. Both the top shock mounts do need replacement.
Car has just shy of 60K
Old Jul 27, 2011 | 01:59 PM
stevepaa's Avatar
scantool software is a must
Old Jul 27, 2011 | 08:05 PM
Spurlee's Avatar
Default Tools
I've done a lot of repair on my car, they are relatively easy to work on, accessible and simple hand tools are good for most everything. My rule of thumb, if I need a special Jaguar-only tool I'm in to deep.
A Scan tool is mandatory (Torque if you have a smart phone) and the JTIS which you can access here on the forum.
I just did my hydraulic hoses. Replace them yourself and you'll get to know your interior pretty well. Take your time - especially on reassembly. Don't forget to install some sort of pressure reduction system while you're at it.
Old Jul 27, 2011 | 08:29 PM
mike66's Avatar
If you're up to the challenge, replace all the rubber in the front end. There are kits available and lots of info here from people who have been there. I brought the parts to a local guy who provided the labor for $900. Was worth it to me because he ran into a frozen upper wishbone bolt that would have caused me much gnashing of teeth and pulling of hair.....but it's like a new car now. BTW, he said the upper bushings from the kit fit just fine, but others here say to go with genuine.
Old Jul 27, 2011 | 09:37 PM
mapatton's Avatar
Many thanks everyone. Went on a discovery expedition tonight for a metallic rattle in the drivers door. Bottom line: after test drive all is good. I will post tomorrow some extras off the thread I used as my starter.
I wrenched on my Jag tonight and was successful. I feel I lost my virginity LOL
Old Aug 4, 2011 | 10:31 AM
mapatton's Avatar
Question, I need a new floor jack. Would prefer a 2 ton, but HF has a 1.5 ton on sale than is now over $100 cheaper than its 2 ton counterpart. Being all I would lift at most would be the front or back of the car, is the 1.5 ton sufficient?
Old Aug 4, 2011 | 10:49 AM
The Coupe's Avatar
I always over-spec with equipment that could kill me...ladders, jacks, whatever. I've got a 2-ton floor jack- bought it at Sears- and 2-ton heavy-duty jackstands. When life and limb are involved, stronger is better, always.
If you shop around at the local stores - Sears, Wal-Mart, the auto-supply chains...you'll find a good deal and avoid a big shipping charge. Those big floor jacks are HEAVY.
Be safe.
Old Aug 4, 2011 | 11:55 PM
H20boy's Avatar
if you're referring to the big orange one from HF, I've got one, my bro-in-law has two. Its effortless and can get it up pretty high. It has worked well for front/rear half lifting on my car. My smaller craftsman struggles on just one corner!
MrWhite
19
Jun 14, 2022 07:49 PM
Msteiner
May 16, 2016 12:19 AM
jagtoes
Apr 22, 2016 07:37 AM
MrWhite
33
Oct 22, 2015 10:29 AM
mrplow58
Sep 30, 2015 08:56 AM
