ZF gearbox fill procedure
Old Jul 14, 2021 | 03:52 PM
keirconway's Avatar
Default ZF gearbox fill procedure
What is the correct procedure for refilling on the these zf gearboxes.
Before i dropped the rear subframe to sort the rust out i changed the oil and filter in my gearbox it was sat to drain for a nearly a week wile i waited for a new sump pan to arrive.
Now when i put it into drive it clunks in and jolts the car.
I filled it ran it put it through the gears until it was between 40-50 and then capped it once it started overflowing.
Have i missed anything?
Old Jul 14, 2021 | 06:10 PM
Stumpy's Avatar
Error
Old Jul 14, 2021 | 06:27 PM
michaelh's Avatar
Sounds about right. Here's ZF's procedure:
Did you leave the old pan in place in the meantime, and what did you refill it with?
Old Jul 16, 2021 | 02:13 AM
keirconway's Avatar
Yea i left the sump on wile it was waiting for the filter and fluid but when i drained it the second time it was still a good litre came out easily
Yea i brought the filter and fluid as one and assumed it was right. I think i have been sent the wrong fluid from what i can see.
They sent me ATF 135.74 not ATF-MV
Old Jul 16, 2021 | 10:39 AM
JayJagJay's Avatar
What does this mean?
Old Jul 16, 2021 | 04:47 PM
keirconway's Avatar
They two types of transmission fluid one is for the 6 speed one for 5 speed. I guess the viscosity must be different slightly.
Busa
23
Oct 5, 2017 12:14 PM
mkontos
Aug 23, 2017 12:19 PM
johnlew
Aug 29, 2014 05:16 PM
Jacob67
May 20, 2014 06:56 AM
