Diesel variants - All models Visit here for discussions on diesel powerplants and the impressive torque / mpg figures achievable....
2.7D, non DPF car, warmup woes
Old 09-22-2014, 11:58 PM
sheppy's Avatar
Default 2.7D, non DPF car, warmup woes
I've got a 2.7D S-Type which misfires at tickover as it is warming up. Its early 2005 so I don't think it has a DPF.
Can anyone offer suggestions before I open my wallet?
I'm in Auckland NZ so there aren't that many of these around here. I welcome anyone that can give me a clue what areas to send my dollars towards. It hasn't brought up a check engine light so far although if the battery is particularly low it will show ABS failure when cranking and extremely occasionally TSC unavailable.
Last year I had the alternator rebuilt and soldered many crimps in the battery circuit which improved the startup faults however the misfire remains.
Old 09-23-2014, 12:22 AM
Received 4,436 Likes on 2,421 Posts
Welcome to the forum sheppy.
The easiest way to tell if an S-Type is the DPF or non-DPF version, is the tailpipes. The early non-DPF models have tailpipes that point down at the road, the later DPF models have the tailpipes that point straight out the back of the car.
No DPF:
DPF:
I'd be looking into a replacement battery to start off with, poor batteries in these cars can cause all sorts of odd faults, believe me it's worth chucking in a new battery...
As for the misfire, it could be a number of things, if it's not putting on the check engine light then there may or may not be a DTC stored, but it's worth reading the codes to see if there is anything there that might point to the issues...
sheppy (09-23-2014)
Old 09-23-2014, 12:24 AM
sheppy's Avatar
It's a NON DPF car looking at the photos. Is there a way of reading the codes DIY or is it a open wallet and visit dealership option?
Old 09-23-2014, 12:46 AM
You can buy a cheap codereader that will read the codes for you.
I have this one Autel MS309 OBD2 OBDII Scanner Can Bus Car Code Reader Data Tester Scan Tool | eBay and used it on a mates 2004 S-Type diesel, it works no problem.
If it picks up Jag-specific codes (where it just gives you the code without the description) then you can look them up in the DTC master list Ford-Manufacturer-Specific-DTC-2007
Old 09-23-2014, 12:52 AM
sheppy's Avatar
Thanks for that - does that one allow me to look at everything on the car or just the engine?
Is it including the right plug for the car or do I need to get a lead?
At that price the dealer wouldn't even unlock the doors let alone open the bonnet.
Old 09-23-2014, 01:19 AM
It will read the engine and transmission related codes only & uses the standard OBD plug which is included.
This will sort you out for fault-finding.
The following 2 users liked this post by Cambo:
JimC64 (09-23-2014), sheppy (09-23-2014)
Old 09-23-2014, 03:20 PM
sheppy's Avatar
Thanks very much - do the more elaborate models allow you to do more things - i'm thinking for the future here - or is that too specialised and really needs JTIS?
Old 09-23-2014, 07:16 PM
The next step up would an IDS/SDD system, or there are also the Autoenginuity, or a new one out now the JLR ST512 which does not completely cover the S-Type functions, but I suspect it eventually will...
Old 09-23-2014, 10:01 PM
sheppy's Avatar
Fascinating, is there anything out there that connects to a laptop so I can see engine parameters when its running? It would be useful assuming nothing is stored to see what the sensors are telling the ECU when its misfiring
Old 09-23-2014, 10:14 PM
The IDS/SDD can do that.
Old 09-24-2014, 06:21 PM
sheppy's Avatar
I think the Auto Enginuity with add on Jaguar Enhancements will allow me to do everything by the looks of it. Not cheap but it should pay in the long run. My climate control isn't working as well as it used to so I think I can use this to tell me what the sensors on that are doing too - I suspect the sunlight sensor has gone bad.
There are plenty that will regas it around here but mention a sunlight sensor and blank looks appear!
Old 09-25-2014, 05:42 PM
sheppy's Avatar
I just ordered the Autoenginuity interface. I'll update this thread when I get it and have added the Jaguar enhancement pack and checked for any stored codes.
Thanks for your help so far!
Old 09-29-2014, 11:58 PM
sheppy's Avatar
Interface has arrived and I added the Jaguar extras.
No diagnostic codes stored from the engine ECU although others are stored for Climate Control, Audio and Parking. I can interrogate and live graph around 300 things for the engine alone.
Can anyone give me an idea where to start looking? Needless to say it was idling smoothly when I was just playing with it!
I'll post separate threads after I've searched the forums for the answers to the rest of it.
Old 10-15-2014, 11:52 PM
sheppy's Avatar
Got a further update on this, the engine is running OK at the moment but outside temperatures have risen so that may be helping.
However I've just come across the port deactivation TSB and the right hand bank (stood at the front of the car looking back) valve diaphragm is leaking. The valve moves if I put a tube on it and suck but only a bit and not as much as the left one which holds a vacuum.
Guess its time to get the service kit, install it and see what happens.
Does anyone know if they are the same part installed on the Ford 2.7D V6? Jag parts in NZ have many people clipping the ticket as it passes so Ford may be cheaper
Old 10-16-2014, 02:33 AM
The 2.7 diesel in the Ford Territory is essentially the same engine, so you might be able to source parts via Ford. Same engine in the Land Rovers too.
Old 10-29-2014, 09:59 PM
sheppy's Avatar
Further update on this.
The intake kit finally arrived and I installed it. Couldn't get the wiper arms off as they'd corroded on but managed to get enough movement in the access panel to get the job done. It took 90 mins to do and I now have working port deactivation valves. Initial impressions are a smoother idle and a long run of motorway and ordinary roads gave me 41.4 imperial MPG and I didn't spare the horses on overtakes. This I think is at least 2.5MPG better than I expected it to be.
I'll update more when I've driven it a bit more.
Both old valves had a split around the diaphragm rim but only one didn't hold a vacuum when I sucked on it with a tube.
Old 10-30-2014, 12:03 AM
Problem solved then?
Old 10-30-2014, 02:44 AM
sheppy's Avatar
Can't say for certain as it was intermittent and usually when it was cold and wet and we're heading into summer, however I'm hopeful and it's certainly noticeably smoother especially when slowing down to idle at lights.
Old 10-31-2014, 10:22 AM
cat_as_trophy's Avatar
Received 1,410 Likes on 876 Posts
Hello sheppy . . . and greetings from another Aussie.
My 2007 2.7L TTD S-Type is the final generation with VIN# final 6 around N80XXX, so quite different to yours in some critical areas . . . not just DPF. But, I do offer 2 suggestions that I believe will help you . . .
  • as Cameron has suggested, do check your battery voltage . . . that grouping of apparent faults are a dead giveaway of an under charged or failing battery, so suggest you review the thread Battery 101 for S-Types and the links provided there to the main write-up and regional Supplements;
  • check out the entire Diesel specific forum here, with special reference to the threads about the 2.7L TTD V6 and recent appearance of Sydney based firm Chip Tuning . . . I get nervous when I hear references to "misfires" in a diesel, because I have to start guessing at what you are describing.
Please don't be backward in joining in our Aussie regional discussions either, because several of us expect growing numbers of the 3.0L XF will start appearing here also. Good luck with the AE tool. I opted for the upgraded JLR full SDD V138 Mongoose PRO, but in my case, an important consideration was that our local independent specialist intends to invest in the same tool . . . so we get to compare notes.
Best wishes,
Ken
The following 2 users liked this post by cat_as_trophy:
JimC64 (10-31-2014), sheppy (11-14-2014)
Old 11-14-2014, 12:11 AM
sheppy's Avatar
Default Further update
Since fixing the Swirl / port deactivation valves the rough running has improved although not totally. Additionally to this it has thrown an EGR code which ties in with seeing one of the EGR valves bouncing all over the place and my guess is the missing valves caused the EGR to work in a different part of its range.
The fuel consumption has also improved markedly, I'd say its worth around 2.5 Imperial MPG on a run and possibly more on mixed motoring. It is however still an almost 2 tonne car so it will never be that economical sitting at traffic lights. Its also noticeably smoother and more responsive at low throttle.
I've just fitted an EGR bypass kit and cleared the stored codes so that's the final piece of the puzzle.
Will update again once I've driven it for a few weeks.
Quick Reply: 2.7D, non DPF car, warmup woes
