'03 S-Type w/Oil Leak
Old 04-26-2010, 07:46 AM
joycesjag's Avatar
Received 1,692 Likes on 1,208 Posts
Congrats!!!!! I am glad to have been "part" of your project. I think we have all been there, where we drop a screw onto the bellypan at one time or another!!
  #42
Old 04-30-2010, 12:58 PM
ndy4eva's Avatar
Rick,
I got a question for you. Do I need to change "upper intake gaskets" when you change the spark plugs? I'm not planning to change the spark plugs yet, but I want to know.
Thanks,
  #43
Old 04-30-2010, 01:29 PM
joycesjag's Avatar
Some will say to change the rubber upper intake gaskets, some will say no need. I did just because I don't ever plan on removing the intake again. I also replaced the 100k spark plugs at 42,000 miles because now I am set for the "life" of our S Type as far as plugs go. Search around the different dealers to find the best price on the uppers (I think I paid around $70.00 for all 6).
Good Luck
  #44
Old 05-01-2010, 07:58 AM
JagV8's Avatar
Received 4,484 Likes on 3,902 Posts
If they're properly springy and will DEFINITELY not leak, don't replace them - but you risk re-doing the job. I HATE re-doing jobs, but you may be different lol
  #45
Old 03-21-2011, 06:23 PM
ant17's Avatar
I'm getting that oil burning too on my XJ8 2003 VDP.
Is the process somewhat the same to replace those IMT O rings?
TIA
  #46
Old 03-21-2011, 06:31 PM
androulakis's Avatar
Good Luck
Do you still believe in that theory after my discovery? (As far as gasket sources).
Oh and the XJ8 has no IMT rings, you need to look elsewhere for the source of your oil leak. It's strictly a 3.0 v6 thing.
Take care,
George
  #47
Old 03-21-2011, 07:04 PM
joycesjag's Avatar
George my post #43 was back almost a year ago and at that time I did not research the Fel-Pros since I replaced my uppers even a year before I posted #43 here. I know aleast Auto Zone, NAPA nor Advanced did not have any aftermarkets available when I needed them in 2009.
Hey did you get that R from Tina?
  #48
Old 03-21-2011, 07:40 PM
Those gaskets have been there since the start, for the 3.0l duratec contours / tauruses escapes. Eventually SOME of the parts suppliers (and I) figured out they fit the Jag Duratec as well.
Tina hasn't had the car long enough to want to deal. 11g's as it sits broken gas gauge and all. 9700 with the gas gauge fixed didn't seem to float her boat
AS you said... give it time, she'll come around!
Take care,
George
  #49
Old 03-21-2011, 08:03 PM
ant17's Avatar
Thanks george.
  #50
Old 03-21-2011, 08:10 PM
joycesjag's Avatar
ant it may be the passenger valve cover gasket leaking onto the exhaust manifold and getting into the cabin via the cabin/pollen filter.
  #51
Old 03-22-2011, 05:09 AM
ant17's Avatar
It didn't get into the car, but I saw smoke coming from the driver side VC area.
  #52
Old 03-04-2012, 03:43 PM
thinking about buying 2005 s type 3.0 91000km asking $11000 cad.,it has a small oil leak pass. side back of motor,looks like valve cover bolt with rubber washer.easy fix or dealer fix $$. do my own work other cars gm oil ,brakes,etc. but jag is new to me. Thanks
  #53
Old 03-04-2012, 04:22 PM
joycesjag's Avatar
IMT O-rings need to be replaced!
Look here: https://www.jaguarforums.com/forum/s...ck-pics-49214/
  #54
Old 03-05-2012, 07:48 PM
Smile
Thanks Rick
  #55
Old 03-10-2014, 06:08 PM
avillanuevaflores's Avatar
i noticed that you are doing this for the v6 s type, do you have any idea where are the imt o rings located on the regular v8 engine???
thank you
  #56
Old 03-10-2014, 06:12 PM
ndy4eva's Avatar
thank you
I don't know where it's located for v8. There might be better Technician who might have better knowledge. As far as, I know v8 don't have IMT O-Ring issue like v6. But again, I could be wrong.
  #57
Old 03-10-2014, 08:36 PM
joycesjag's Avatar
There are no IMT O-rings on any of the V8 engines.
  #58
Old 08-26-2019, 06:26 PM
JagloverRSA's Avatar
Default I have the exact same issue - I am also so new at car DIY
Originally Posted by Brutal
If i had a $1000 for everytime someone said or change a cam gasket needlessly for that i could buy a new camaro, seriously. If you look at the black imt valves on the back of the intake right above the alledged cam leak onto the exhaust. Youll see they have 2 8mm bolts each that hold them in, take out the bolts and pull the imt vavles strainght out after you disconnect the electrical connectors. Take off the oring on each 1 and replace with the green jaguar ones(the green is a sealant)
now if it is your cam covers it will still be leaking after you replace the imt orings and then you can spend the serious money!
Good day,
Please be forewarned that I basically don’t know the 1st thing about car engines and may very well make you weep with my intense lack of knowledge.
My late 2004 S-type 3.0 V6 has this exact issue. Just an extension in my query which is not within my sphere of knowledge:
Could the oil leak also cause loss of power/laziness unless fully depressing the throttle - after a backfire suddenly all the power is available? Spark plug covered in oil?
The leak is worse at idle - and only when engine is at operational temperature. At the same time I get a flickering oil light, which like the leak, disappears the moment I touch the accelerator.
The car has 161,000 km on it with one previous owner and a comprehensive maintenance record with the agents
Thank you in advance.
Ozzy_UK
General Tech Help
01-14-2016 02:52 PM
captbob73
10-24-2015 05:49 PM
arskemp
09-21-2015 02:19 PM
Tim Goz
09-17-2015 09:11 AM
Quick Reply: '03 S-Type w/Oil Leak
