AC Recharge Location
Old 04-28-2010, 11:03 AM
lylon's Avatar
Default AC Recharge Location
My 2003 S-Type takes a while before the AC blows cool air - about 10 minutes after ignition. I noticed this last summer when it took about 3-5 minutes to start blowing cool air. I suspect it is low on R134a and I plan to get a recharge kit. Where is the low port location for the AC? How difficult is it to get to for a first-timer?
Thanks,
Old 04-28-2010, 03:00 PM
chucky60's Avatar
Wink
Thanks,
On the 2000 4.0 V8, It's on the pump. But you may want someone to check for leaks first, so you don't waste your time filling a system that may have leaked the oil for the pump along with the R134.
Old 04-28-2010, 11:12 PM
androulakis's Avatar
Look behind the driver's side tire, its much easier to see from underneath. Its basically behind the spindle.
George
Old 05-06-2010, 08:14 AM
lylon's Avatar
Thanks for the help, guys. It was not that difficult to get to with the wheel turned a bit. However, my pressure appeared to be fine so the level of R134 is acceptable I supppose. Just to be sure I may check again later.
I'm not having an issue with hot air from some vents and cold air from others - that would make me suspect the DCCV. Does anyone know what might cause the air to take nearly 10 minutes to get cold? After a few minutes it just goes from warm air to perfect icy cold and is fine after that.
Old 05-06-2010, 08:29 AM
Jon89's Avatar
Received 4,276 Likes on 2,813 Posts
In a couple of my long-gone vehicles that used R12 back in the day, requiring awhile for the system to begin blowing cold air typically pointed to low refrigerant. I would suspect the same with R134a although I've yet to experience that problem on any R134a vehicles that we've owned. Call around to some local AC shops, describe your situation, and listen to what they have to say....
Old 05-06-2010, 08:35 AM
Check the low and high side pressures with the system running. Use real gauges. A low side pressure condition is harder to catch, especially with a cheap refill can gauge.
Also check to see that the aux fan over the condenser is running with the compressor spinning.
George
Old 06-16-2011, 06:26 PM
badmojo's Avatar
Is the low pressure AC port also in the wheel well on the 4.2 V8 R?
Thanks!
Old 06-16-2011, 07:28 PM
searanch's Avatar
Thanks!
yes - just did mine after a radiator replace...
Old 06-16-2011, 08:29 PM
joycesjag's Avatar
Received 1,692 Likes on 1,208 Posts
carelm (08-17-2011)
Old 06-17-2011, 10:38 PM
badmojo's Avatar
Hey Thanks!
Old 03-28-2018, 05:46 PM
Don Duncan's Avatar
one side of my vents o n my 2005 stype jaguar is blowing cold. The other hot. Any suggestions
Old 03-28-2018, 06:20 PM
Received 2,579 Likes on 1,784 Posts
Use the forum search function. Read these threads:
https://www.jaguarforums.com/forum/s...003-faq-36719/
https://www.jaguarforums.com/forum/s...e-start-36924/
Old 03-28-2018, 06:47 PM
kr98664's Avatar
Received 1,984 Likes on 1,401 Posts
Originally Posted by NBCat
Oh sure, give the poor guy some clear, concise information...
How about some long-winded verbose prose instead, written by some guy obviously channeling the spirit of Marcel Proust?:
https://www.jaguarforums.com/forum/s...ol-how-185002/
The following 2 users liked this post by kr98664:
motorcarman (03-28-2018), NBCat (03-28-2018)
Old 03-28-2018, 06:59 PM
Thank you for that very un-concise, yet content-laden diagnostic procedure that is truly inspired and well written!
jimforrest (uk)
02-28-2019 06:42 PM
jorgef858
01-14-2016 11:32 AM
damienedwards
11-22-2015 10:51 AM
zoozth
09-29-2015 07:28 AM
Quick Reply: AC Recharge Location
