ticking on startup
Old 01-01-2013, 12:02 PM
darren-talbot's Avatar
Default ticking on startup
intermittently i get a tick tick tick tick in fast sucssesion on cold start up then the revs come down down as the auto choke sorts itself out and it goes away,
just to clarify ive already had plastic chain tensioners replaced
thanks
darren
Old 01-01-2013, 12:11 PM
bfsgross's Avatar
Just the cold weather messing with fluid viscosity and moving parts.
darren-talbot (01-01-2013)
Old 01-01-2013, 12:21 PM
thanks dude,
thats what i thought after about 5-10 seconds it gets quieter and quieter and gone as the oil flows around it i guess.
Old 01-01-2013, 12:54 PM
clubairth1's Avatar
Received 2,239 Likes on 1,767 Posts
You have the old style V-8. Have you changed the tensioners?
They make noise on start up when worn.
Old 01-01-2013, 01:23 PM
bfsgross's Avatar
He changed the tensioners.
Old 01-01-2013, 01:45 PM
clubairth1's Avatar
Oops! Sorry it's hard to keep every problem separate!
Old 01-01-2013, 03:25 PM
avt007's Avatar
Does revving it to 2,000 rpm make it suddenly go away?
Old 01-01-2013, 03:56 PM
JagV8's Avatar
Received 4,484 Likes on 3,902 Posts
Heatshield / cats heating up?
Old 01-01-2013, 06:59 PM
bfsgross's Avatar
Default Without Revving
It goes away when warmed up returning from cold choke rpms to idle rpm.
Old 01-01-2013, 07:55 PM
Received 10,312 Likes on 6,822 Posts
Agreeing with all said.
We have a few here in our little group, and oil viscosity is the prime cause. Since the tentioners are done, all OK there.
Most here run Sythetic 5W/40, or 5W/30, and no noise ever. One used 10W/40 once (brain fade), and ticking when cold, mmmm. changed it out, all silent.
Old 01-01-2013, 08:12 PM
cbharley10's Avatar
Only other thing to double check is the oil level. I was losing some oil with my leaky valve covers and although it was negligable loss I would experience a tick tick tick on startup when the oil was anywhere below the maximum fill line...
SD96XJ6L
01-12-2022 04:30 AM
Chuck Schexnayder
33
10-24-2015 10:20 PM
jospolice
10-02-2015 07:16 PM
willemh
09-28-2015 06:22 AM
Quick Reply: ticking on startup
