Str 2006+ 355mm brakes
Old 10-29-2022, 11:32 AM
elDariusVargas's Avatar
Default Str 2006+ 355mm brakes
Hi!
i have a problem with my front brakes. Both sides... (355mm str facelift brakes, or xf 5.0 na)
my inner pads (piston sides) do not sit parallel with the rotors. They sit with their lower edge (the one by the hub) towards the rotor and the upper edge is tucked in in such way that they do not touch the rotors on its outter edge, not even on braking.
The outer pads they sit perfect.
is this a common issue?
thanks!
Old 10-29-2022, 11:54 AM
xalty's Avatar
Received 1,038 Likes on 834 Posts
did you clean the pad ear contact areas with a die grinder or media blast?
Old 10-29-2022, 01:25 PM
yessir i did
Old 10-30-2022, 10:02 AM
Piston seems parallel and straight
See how the disk is polished by its center?
See how the outter edge of the pad doesn't get contact (upper view)
See the same thing (exterior view)
I took pictures today.
everything is cleaned, piston seems straight
pads and rotors are surfaced perfectly.
both calipers do the same thing
old pads had diagonal wear... si clearly something is off
Old 10-30-2022, 03:43 PM
Sportston's Avatar
What brand of pads are you using?
I can think of five possible reasons for this:
1. You’re looking at this when the wheel is off and the disc has no securing screws installed, causing it to move at an angle.
2. Incorrectly installed springs in the calliper hangars or rust behind them pushing them out of line.
3. Poorly manufactured pads.
4. Poorly manufactured discs.
5. One of the sliding pistons is seized (assuming your brakes are of the sliding piston type and not opposing pistons).
Old 10-30-2022, 05:53 PM
awesome points.
i personally was convinced it was the rotor that's not tight, but then i remembered i have spacers installed so they keep the disk tight, haha.
caliper springs and pistons are perfect, i used a digital measuring caliper to check all the distances and they are good.
Pads and disks were new but they sat a long time on standby, so i had them resurfaced and measured with a caliper and they are perfectly flat.
i must send ate an email.
maybe my textar pads are just stupid. I mean they dont even cover the whole disk area. But their part number matches these calipers and they fit right in the slots.
i am wondering if the calipers have settings in regards to the pads-rotors gaps
Old 10-30-2022, 07:55 PM
Sportston's Avatar
I’ve never heard of Textar. I wonder if that is the problem.
I would suggest trying a quality brand. EBC are, in my experience, the best value for money (you don’t need to opt for the gimmicky sintered green stuff or red stuff. Their standard ones are best). Mintex are ok. Lucas TRW are ok. Blueprint are ok. Delphi are another good one as are Bosch.
AVOID Ferodo! They are poor quality these days.
When buying brake components, always go for quality stuff. It is a false economy to buy the cheapest discs and pads because they either warp, squeal, or don’t fit or work well. Also make sure they are the right part listed for your car.
One other thing to check: some pads have a raised locating blob on the back. These are designed to fit on the opposite side to the piston. The ones on the piston side have no blob. If you have installed them the wrong side the blob can cause uneven pressure.
Did you check both the sliding pistons move freely?
Old 10-30-2022, 08:09 PM
xalty's Avatar
textar is reputable brand subsidiary of nisshinbo.
brand new pads will sit crooked that’s just how they are. it’ll wear even as it smooths down
Old 10-30-2022, 08:18 PM
Sportston's Avatar
Ah right. I stand corrected. It’s not a brand I have come across in the UK.
Forgot to mention Brembo are also good quality.
Old 11-06-2022, 03:51 AM
neilr's Avatar
Yep, I wouldn't worry about Textar quality, it is the top brand from TMD in Europe above Pagid and the budget Mintex, and an OEM for many car manufacturers. Ferodo is part of Federal-Mogul and they are producing some very good high-friction road pads these days, along with their sister brand Jurid. I have the Jaguar/Jurid 233 pads up front and Ferodos on the rears. Best road combination for the Lucas brakes on the older S-Types I have yet come across.
However, for the later S-Types with the ATE brakes, they are single piston types, right? I would make sure that every moving part moves freely, including the piston itself. A sticky piston could well cause the problems you describe, allowing the pad to drag more than it should.
S-Type Owner (11-06-2022)
Old 11-06-2022, 06:12 AM
Sportston's Avatar
I take it you haven’t noticed the Ferodo tendency to squeal then? I stopped using them due to customer complaints about noise. Mind you, that was 7 yrs ago. I guess they could have improved since then.
Old 11-06-2022, 09:57 AM
neilr's Avatar
Nope thankfully But I only have experienced light squealing when the calipers are clogged up and so probably pretty much independent of pad manufacturer. The XKR has just come through it's bi-annual TÜV test and the GG rated Ferodos put up results that are the best yet and they somehow really minimize that light graunching noise that automatics always seem to make from the front brakes on a very light stop. On the move they are absolutely fine. The S-Type also has no problems except for the naturally rather heavy pedal. Here, high friction pads all round really help to give a bit more bite at light pressures. At heavier pressures it always seems to work fine.
Old 12-09-2022, 01:47 PM
sycorax's Avatar
Hi elDariusVargas,
The 2006+ STR brakes are different than the Bremo's of the previous models, they are ATE-Teves and most part sellers tend to give you the wrong parts. I have replaced the front brake discs and brake pads and after some research I found the correct ones but the part seller would not give me a free return guarantee because he was certain that this where the wrong parts. But they fit.
Brakepads look like this:
Old 12-09-2022, 04:24 PM
JagV8's Avatar
Received 4,484 Likes on 3,902 Posts
Please don't keep posting the same info on lots of threads!
Old 12-11-2022, 06:11 AM
sycorax's Avatar
Hi JagV8,
I'am not sure of this remark i intended for me, but if I have done something wrong it was not my intention to do so. I was replying only ones to a post of alDariusVargas regarding his brakes.
Old 12-11-2022, 08:08 AM
JagV8's Avatar
Originally Posted by sycorax
Hi JagV8,
It wasn't about you - the person concerned looks to have been banned & posts removed.
Old 12-27-2022, 11:27 AM
hi, i am back with updates on my calipers.
Before i installed these XF 5.0 or STR calipers on my stype, theyve been rebuilt and greased with ate caliper grease, everything like new.
Still dont know why the angle was weird regarding the inner pads, but i drove it like that afterwards.
of course they worn out 1mm and now they sit right on the disk, but still, if i were to put new pads and disks, chances are thy gonna sit angled in the beginning.
Now as an experience after the upgrade: low speeds you can feel slightly more braking power, but above 50kmh, i have leverage with these wide disks. Way easier to stop the car. i mean, from 280mm (iirc) to 355mm, it is noticeable difference!
As you guys described the s type's hard pedal, its weird, and i might also try to add a vaccum canister to test if i can increase the braking power.
i am wondering if these brake boosters are notorious for any faults? is there something special to test them for? If i shut down th engine with the brake pedal pressed it doesnt push me back.
Old 12-27-2022, 05:39 PM
clubairth1's Avatar
Received 2,239 Likes on 1,767 Posts
Not sure what you mean by a vacuum canister?
Your power brakes are vacuum powered already?
Old 12-28-2022, 05:03 AM
it stores vacuum. mostly used in applications where the engine cant produce enough. cammed engines, old big block engines etc
thats regarding s type hard brake pedal. lets see what happens.
Old 12-28-2022, 12:57 PM
xalty's Avatar
x202 x204 = sponge
x206 = rock
elDariusVargas (12-30-2022)
Quick Reply: Str 2006+ 355mm brakes
